Loader Bolt-on teeth for Kioti KL6010 loader?
/ Bolt-on teeth for Kioti KL6010 loader? #1
davepete
Eau Claire
Kioti NX6010 HST
I took delivery on a new NX6010 HST today. I'm going to be using it initially to do some digging/site prep for a new garage. I've been thinking about getting a tooth bar for the loader to make the digging easier, but today I noticed the loader bucket already has a series of holes drilled along the front edge, seemingly right where teeth could be bolted on. Does anyone know if that's possible and, if so, which teeth would work? Most of the bolt-on teeth I've found have two holes for bolting each tooth, but my bucket only has one hole per location. Any info would be appreciated.
/ Bolt-on teeth for Kioti KL6010 loader? #2
I think the holes in your bucket are for a heavy cutting bar.
I kind of figured it would be something like that. Anyone have any recommendations on a good tooth bar that would fit the KL6010?
/ Bolt-on teeth for Kioti KL6010 loader? #4
I was able to pick up this bucket for $160.00 and put a QC on it. Then added the grabber and the teeth. The teeth was right at $25.00 each. The cyl and hoses were about $120.00. In 2nd picture you can see the holes you are talking about.
/ Bolt-on teeth for Kioti KL6010 loader? #5
I think the six or so holes in the loader are for a wear blade, or individual loader teeth. There isn't lots of info on teeth, most people just buy a tooth bar and just drill two holes on the loader bucket sides to install.
I too would be interested in teeth.
/ Bolt-on teeth for Kioti KL6010 loader? #6
Leejohn,
That bucket and graple look like they mean business. I wouldn't want to take you on in a tractor fight.
/ Bolt-on teeth for Kioti KL6010 loader? #8
Tooth bar is about the best thing you can do for your bucket+a thumb.
Tooth bar came from Markum Welding(don't know if they are still around),I think Michigan Iron has them.
Just measure the inside of your bucket less 1/2" and drill and bolt on.
/ Bolt-on teeth for Kioti KL6010 loader? #9
I put a wear bar on my PX 84 inch bucket and they also had a bolt on tooth bar that would fit too. Not that expensive and my wear bar works fine.
/ Bolt-on teeth for Kioti KL6010 loader? #10
Piranha Tooth bar We love ours and I can't say enough about customer service.
These are all custom made to order to your specific bucket measurements (note: not "size" - your actual measurements because all buckets vary slightly)
If you do a search on the forums you will find several threads on them.
Good Luck with whatever you pick.
Glad to hear you like your Piranha bar. I've had my eye on that one for a while now, and I'm pretty sure that's what I'm going to go with. :)
