Repair manual needed
/ Repair manual needed #1
Danjkelly
I have a LB1914, with a electrical problem. The Alternator light comes on at working RPMS. When the unit is shut down the oil & Alt light up dim. I am at a loss.
I can't find a manual for this machine (Kioti is out!)
Any ideas?
/ Repair manual needed #3
I just went out and looked at a LB1914 on my lot to make for sure, but the oil and alt light should light up when the engine is turned off and the key is on. The oil light is brighter than the Alt when you turn the key off. Alt light should go off when engine is started though. What year tractor is this?
/ Repair manual needed #4
I'd try disconnecting the battery after you start the tractor to see if it continues to run off the alternator. If not, get the alt. checked. You are probably only running on the battery. John
The 1914 only has 75 hours on it, it is two years old.
When I removed the Neg Battery cable the tractor continued to run fine. BUT, now the Alt light stays on and when the tractor is shut down, and the key is OFF Both Alt & Eng light is on real dim. The selling dealer is gone, but said it is a Old Style Kubota. Will a Kubota service manual be the same? Is it designed after a Kubota?
/ Repair manual needed #6
They are not designed after Kubota. The two companies are not related in anyway, so service manuals are not the same. The dealer was just telling you a tall tale that is just not ture. The engine should run fine with the negative battery cable off as it is a diesel and doesn't require the battery to run. Removing the battery cable or running the engine with the key off can cause damage to the electrical system of the tractor though. It sounds to me like you need to replace the regulator on your tractor. It is located up on the inside of the firewall.
/ Repair manual needed #7
I would double check all the ground wires.
/ Repair manual needed #8
That's a good way to blow the rectifier (big diodes) in the alternator. Furthermore this would prove nothing; Diesels run quite happily with zero electricity except where the shutoff solenoid is spring loaded to shut off the fuel when power drops (some newer ones work this way).
This sounds like you finished frying the alternator. You probably had a sick voltage regulator initially and you probably also have a sick rectifier (diodes) too now.
At this point I'd advise taking the alternator to your nearest Autozone, Advanced Auto, etc. and get it checked out (they'll do it for free). Be sure to disconnect the battery negative cable (with the engine OFF) before you remove the alternator.
/ Repair manual needed #9
This thread is from 2004
/ Repair manual needed #10
I gotta start looking at the date vs just seeing a "new"post! Thanks Murph.
/ Repair manual needed #11
That used to happen to me a lot. I am learned now.:laughing::D
/ Repair manual needed #12
Bad idea disconnecting the ground cable to the battery when the tractor is running. If you didn't have electrical issues with your alternator/ V reg you likely do now.
Before you replace anything, take a meter and test voltage at battery with tractor off. Then see what it reads with the engine running; then again with headlights turned on.
Report back results.
I see you guys posted before I got this posted, now I see that it's a dead thread?! Why would someone revive a thread from '04?!:confused2::confused3:
/ Repair manual needed #13
Here we go again:laughing::rolleyes:
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2001 Peterbilt 378 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2001 Peterbilt 378...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
