/ Harbor Freight Tools that don't suck #5,542
I had to shim the foot putting a nut under one edge, to get its notch parallel to the blade so I could estimate where it was going to cut.The guide roller screws were loose and soon fell out. After completing what should have been final quality control at the factory it's a good tool.
California,
Are you talking about cutting in the vertical mode? For horizonal cutting, I just lay the blade down on the material to be cut, it shows exactly where the cut will be. You probably do that too.
/ Harbor Freight Tools that don't suck #5,543
No issues with mine on alignment but then mine is old. I replaced the guide rollers a while ago with good skate bearings. Mine had served me very well, but mine was 150 bucks, not 250. Inflation is inflation so the 250 is really 150 anyway.
/ Harbor Freight Tools that don't suck #5,545
An ice dam took down part of our gutter. That pulled the soffit open on the north side of the house. A bird went in, and managed to go up and over two peaks to the west/south corner of the soffit and was flapping around in there for 2 days, right outside our bedroom window. It couldn't find its way out. So, I had to use a 6' step ladder to open up the end of the soffit, then go and pound on the soffit with a broom handle upstream of the bird to chase it down to the now open end. Just as the bird poked its beak out of the opening, the opening snapped shut. So I asked my wife to stand next to the ladder while I climbed up to re-open the soffit end. She did exactly as I asked... she stood next to the ladder. I didn't ask her to hold it. :laughing: As I went up 3-4 steps the ladder pretty much jumped out from under me. It went left, I went right, the back of my head hit the house, my back landed on the ground, and my butt landed on the ladder. I laid there for about a minute expecting something to start hurting.... nope. Just my pride. I was sore the next day, though. :rolleyes:
Same thing happened to me and note to others. If you want the wife to actually hold the ladder you have to say so. Assume nothing.
I was at the top of a 25 ft ladder many moons ago and wife was at the bottom, presumably holding the ladder I asker her to stand next to. When I glanced down from the top rung she was just standing there. "I did what you asked me to". With corrected instructions spoken quickly and loudly, we were back on task.
/ Harbor Freight Tools that don't suck #5,546
One of my interests, in the HF Bandsaw is ability to operate horizontal or vertical. Do you guys use your vertically? Any issues with the table?
The stand is flimsy. Replace it if you can. Have never used mine vertically, never had the need.
TSC and HD sell the 64½" blades.
/ Harbor Freight Tools that don't suck #5,547
I've used my HF bandsaw vertically many times. When ripping, I often clamp a straight edge to the auxilury table to use as a fence. I've also used the saw to chamfer the edges of stock before welding it.
The table was way too low to suit my back. Building a taller one was one of the best things things I did.
/ Harbor Freight Tools that don't suck #5,548
California,
Cutting horizontal, like a hacksaw.
I started out and all my cuts curved off to one side. On examination, the shoe the blade passes through was way out of line with the direction of cut and giving me a false impression of where the cut would go, so I shimmed it true.
Here's a post with photo I put over on Welding Web illustrating this.
Any luck with the HF porta band?
/ Harbor Freight Tools that don't suck #5,549
Calfornia,
Thanks for explaining. I didn't realize yours was a porta band.
/ Harbor Freight Tools that don't suck #5,550
I've only used the table a few times over the years. Its more of a bother to find it and the mounting screws from the last time I used it. It works O.K. :laughing:
When I first got my HF 4X6 saw, I used the vertical table a few times. I agree, it is a pita, esp. for a small/short cut, then have to remove it to cut horizontal. Now, for vertical use, I just use the small flat square around the blade (where the table mounts) as a "table". All I ever do is saw a notch or a short curve, and that little spot of support is all I need.
/ Harbor Freight Tools that don't suck #5,551
Yes! That is one of the few gems they have. Immideately drain the worm drive oil and replace it with something quality. Rumor is (this was years ago) that it was a crap shoot what kind of oil they put in. Once properly adjusted they are great. Helped a friend make a stand that held cutting fluid and we made it just like the more expensive model that will cycle cutting fluid through a goose neck keeping the part you're cutting cool.
I think I got mine for like $175-180.
Another thing I forgot to mention about the 4x6 HF bandsaw ... an 8 oz. tube of Skil Worm saw oil is enough for an 'oil change' in the worm gear box. If you read that Bob's the Oil Guy link, it takes a straight 140 weight gear oil but worm drives want a AGMA Class 7 or 8 oil and if you look at the MSDS of the Skil oil it is basically Shell Valvata J 680.
Both Lowes & Home Depot show it on their web site but it's a mail order or ship to store kind of thing. I've never seen it on the shelf there. Harbor Freight does carry it ... they keep it right beside their worm drive circular saw but it's more expensive than mail order:
Worm Saw Lubricant
edit: The oil level should be to the edge of the worm box cover when the saw is down in the horizontal position. Also store saw in down/horizontal position to help prevent leaks.
/ Harbor Freight Tools that don't suck #5,552
Agree, Skil Worm saw oil seems closest to what all the HF tools need - angle grinders, drills, bandsaw, anything with worm gears or just noisy straight-cut gears.
Anybody know if outboard motor lower unit grease is similar, and suitable for this application? it's easier to obtain.
/ Harbor Freight Tools that don't suck #5,555
Anyone have experience with the $99 motorcycle lift/jack?
/ Harbor Freight Tools that don't suck #5,556
I have one. It's tippy with a bike elevated. Mine is a Sears and Grabbuck but the HF one is the same. Mine works better for the lawn tractor to clean the deck than the bike.
/ Harbor Freight Tools that don't suck #5,557
Purchased the Harbor Freight Portable Miter Saw Stand Heavy Duty Mobile Miter Saw Stand today. I'm really impressed. Well designed and well built. Sturdy legs fold in easily and stand rolls around on wheels and will stand up like a hand cart taking very little room. The guy at HF said that they are new and he can't keep them in stock. He had one and I bought it. Compares to $200 stands at big box stores. On sale for $120, $95 with 20% coupon.
/ Harbor Freight Tools that don't suck #5,558
FYI
Here's the best price I've seen on the highly regarded red stackable tool cabinet. I bought one after the favorable reviews here and it is excellent quality. I got this coupon in an email flier from them but it's only good for a couple of days. It would be on their website too, I would guess. It's rare to see them under $340 and this is $299.
I had to print the bottom barcode because it wouldn't attach to the upper portion. Best to print an original from their site but it seems these two together should work if you buy one.
/ Harbor Freight Tools that don't suck #5,559
I'm considering a couple of their 44" tool drawers. Anyone with good or bad experience with them?
Roller Cabinet - 44" Red Rolling Tool Cabinet w/ 13 Drawers
I'm think of installing 2-3 of them side by side, one wall of shop, with a work surface on top to time together. Remove side handles so they can be pushed together.
Something like this.
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
TOOLBOX (A60736)
TOOLBOX (A60736)
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
