pt 425 engine alternatives
/ pt 425 engine alternatives #1
scotts562
I have a 2005 pt 425 with the Robin Subaru engine that will be getting a hydraulic pump rebuild soon. I would really like to change the Robin engine out for a more dependable/easier to start engine, such as a Honda or Kohler, at the same time. I know Power Trac used to use Kohler engines in 425s, but I am under the impression that there were extensive modifications made on the newer models to accommodate the Robin engine. After several hours of searching this forum for this, I have not found a clear answer.
I did find a couple of engine conversions on 422s but the gas tank/battery/heat shield configuration is different than on my machine. I also found a post where someone converted a 425 to a Kubota diesel, but the original poster did not give any details.
Can someone recommend an engine that will fit into a 425 without a bunch of modification to the machine?
Thank you for the help
/ pt 425 engine alternatives #2
What is your configuration?
-two pumps bolted together on front of engine
-pump on front and rear of your engine
-muffler inside the engine compartment on front of engine
-muffler inside the engine compartment on back of engine
-muffler mounted outside engine compartment with exhaust header on front of engine
PT changed the 425 arrangement as many times as they changed the 422 arrangement. The engine in the 425 and in the 422 are identical dimensions, so what they built into one, they built into the other.
If you have the stacked double pump, then engine replacement with a like size Kohler should be simple. One challenge is that there is no telling what size the stub shaft on your engine is until you take the pump off, since it seemed to change a few times over the life of the 425. Assuming you measure before buying, then the only modification required is (usually) to cut the shaft on the engine shorter than stock. Buying an engine with the wrong diameter shaft (because it is cheaper or available) just means you have to purchase a spider (love-joy) connector of the right size, which isn't that big a deal. You probably want to change out the spider anyhow.
If you have the pump on the front and back of the engine, then you will need to buy the "Front Drive" AND "Front Drive Adaptor" kit to mount a stub shaft on the fan side of the motor.
The threads you read about extensive modifications were probably ones where people were trying to shove a water cooled Kawasaki EFI 27 hp (short story: doesn't fit) into the PT.
When I replace the engine in my beast, it will probably be with a 27HP EFI model. Both Kohler and Robin make one, and it is the same size engine as the stock 25 hp engines that is in the PT425.
Thank you for the information. I suspected a Kawasaki, or any other water cooled engine, would not fit. I will officially scratch it from the list. I will take a look at the 27HP EFI Kohler.
I have two pumps bolted together in front of the engine with exhaust outside the engine compartment from the front of the engine. I have tried to attach a picture (it is the same configuration shown on the Power Trac website.
It will not be a problem determining shaft size. I have already changed this engine out twice and have a re-built spare sitting on the shelf. I was going to re-use the love-joy coupling, but now that you mention it, I will replace it.
/ pt 425 engine alternatives #4
Looks almost like my 2005 PT-422, except my battery is on the floor of the tub instead of in front of the exhaust manifold. From the looks of it, your engine tub must be about 4" longer then mine.
I think the Kohler ECH749 (26 hp EFI) would be a nice engine, and Small Engine Warehouse has a couple for $1600-2100. Specs on this state it is 2.3" longer than the Robin EH72, so it might be a bit crowded.
/ pt 425 engine alternatives #5
You have read the post where one person in this group has moved to Harbor Freight engine. Basically a honda rip.
Tmarks: It is kind of neat that our machines were both manufactured in the same year. I took a look at the Kohler ECH749. Assuming I can get a shorter air filter for it, it might work. It would be very tight. I have 2.75" from the end of the pump to the hydraulic tank (only 2" from the hydraulic line elbow to the PTO valve). The engine sits tight to the engine cover hinge bar and I have 1.25" exhaust to heat shield and 2" engine to heat shield. Overall tub measures 32.75" (engine cover hinge bar to hydraulic tank) and 33 3/8" (frame to hydraulic tank). If it is not too much to ask, could you measure the distance from the hinge bar to heat shield on your machine and the end of the pump to the hydraulic tank? Maybe I can do similar to what others have done with PT 422s. I have been doing some research and am now considering a 23 HP Briggs Vanguard. The dimensions look like it would fit nicely. I am not sure if I am reading the power curve data correctly, but it appears as though this engine provides more power at the lower RPMs than the Robins.
Woodlandfarms: Thank you for the reply. A Predator engine was my original thought. Gotta love Harbor Freight. Predator Tracs did a great post on his conversion of a 422 to a Predator engine. From the pictures he posted, I assumed I would have clearance issues with the heat shield. The battery on my 425 sits behind the gas tank, not under. Tmark's input makes me wonder if my assumption is wrong. From information I have gathered from this site, I know the 22 HP Robins is the same size as the 25 HP Robins. It never occurred to me that the tub on a 422 may be shorter than the tub on a 425. I assumed the frames on a 425 and 422 were identical and only the engine/ROPS/lift height were different.
/ pt 425 engine alternatives #7
Cliff's Notes version: 35hp Robin EH90. Requires drilling new holes in the tub and shortening the spacers under the engine. Chuck the pump adapter in a lathe to accommodate the different centering spigot and drill a couple more holes for the asymmetric bolt circle. Hack and weld an exhaust system. Enjoy 33% more displacement and around 40% more torque. Cackle maniacally. Don't think too much about fuel usage. It will still vapor lock on occasion.
Oh, yeah,
Feel slightly guilty because you still haven't posted the pics & build thread...
/ pt 425 engine alternatives #8
Today, I ordered a 25 HP Kohler from Equipatron to replace my 22HP Robin/Subaru. $1529 free shipping. We shall see how it goes.
/ pt 425 engine alternatives #9
...35hp Robin EH9...feel slightly guilty because you still haven't posted the pics & build thread...
so what do we have to do to make you feel more guilty?
:D
Because we WILL do it...
Back to the OP... more power is better. I know my 22HP just doesn't have what it takes for field mowing (I have a choice: drive fast or spin the blade fast.... don't get to do both). I know that if I re-powered I would look for more hp at the rpm of interest, not just the same or slightly better.
/ pt 425 engine alternatives #10
The Robin Subaru engine combined with the lack of heat management added up to a failed engine and no warranty support from Subaru. Lame. 349 hours.
Sticking with gas...I would highly recommend the Honda GX670 or 690 for the PT, same form factor as the Predator (which is a gx670 clone)
However, I replaced my terrible Robin engine and hazardous muffler...with a Kubota D662, complete with radiator. I did have to modify the back of the tub and cage a bit to accommodate the extra 2" of engine/radiator. This engine (as configured by Jacobsen for a golf couse mower) produces 18hp @ 3000rpm. Any 3-cylinder kubota should fit as easily as this one did for me. At $500 bucks the mower carcass offer me a lot of hydraulics and the diesel engine and was worth it...but I'd go for the D772 or 905 if doing it again. The oil cooler stayed in the same place, same battery and gas tank (purged and cleaned) I even re-used the wiring harness...I'm adding a hyd circuit to eliminate the attachment change shuffle and I'll try to get some pictures up.
Now that trail building season is back for me, I'll be re-hardening the back of the PT425 with the grill/guard of a little dozer....that will give me filtration to keep grass etc out of the radiator as well as rear facing lights! and steel between me and whatever I back into....
I have slightly less power in ground engagement, like trenching, but far better low end response and almost 40% better fuel economy. I just broke raw ground with the tiller and power rake to make a start-up farm patch for a landscape client. No problem. Basically you just have to re-learn where the power curve and stall points are....
I don't feel the hit on power since I have resurrected a toro dingo from the scrap yard and switched it to the Power-Trac QA setup. With it's higher pressure, it handles the ground attachments when I need it to.
/ pt 425 engine alternatives #11
I just want to say "you are my hero!"
Also, I want to say "THIS THREAD IS WORTHLESS WITHOUT PICTURE!" :D
Please?
/ pt 425 engine alternatives #12
Alright, these pictures look like a crime scene, but they'll have to do. I'd just brought the machine in from a very dusty job and decided the engine cover had to go.
0420161213_HDR.jpg 0420161213a_HDR.jpg 0419161955_HDR.jpg 0419161955a_HDR.jpg
The pt425 looks like a dusty train wreck. Here's some notes on what you are looking at.
I'm ditching the steel engine cover, that thing is both useless and killing me....pretty sure the dirt intake with the RObin contributed to it's death. So, I went to metalscut4u.com and ordered three aluminum cuts to enclose the sides and top/front. that can replace the heavy burdensome cage. They'll laser cut in the circle for the fan and the oil cooler will mount just like it used to. With the radiator fan sucking in lots of air and the oil cooling fan expelling lots of air...and the cooler diesel...not to mention adequately sized and positioned exhaust...I'm not real worried about heat. I'll have space to mount the air filter safely inside the housing and that will also reduce the intake of junk.
I've got a baffle/heat wall that will mount between the exhaust and battery....I'm thinking it will be fixed to the sides like the new back of the cover (gray w/ lights in pics) The top of the cover will lift on a hinge in the same motion the original one did....but without weighing in at a sketchy 90#.
The final routing of the muffler 90 down and out the back. That mass of wiring is from the Jacobsen donor machine...It will get cleaned up and the ignition installed under the cover. Check the oil, check the fuel...turn the key. No more snagging keys up front (I work in some pretty hairy conditions) and no starting fires with that PT muffler. The existing throttle and choke cables worked just fine, in fact, they reached perfectly to handle throttle and Kill(instead of choke).
The new hydraulic cylinder valves are next to the stick for the loader, one will handle grapple duty the other will see action on a forthcoming rear 3pt or similar....I can reach them all with one hand while running the loader stick...how convenient.
Other than the radiator sticking out 2" past the end of the tub steel and the engine cover...which was handled unceremoniously with the reciprocating saw....The only accommodation the kubota d662 (or d772) required were 4 6" .25 thick engine mounts. 90 degree bend in the last inch on one end 3/8 bolt holes both ends. With the mounts and a new bellhousing from Hayes to join the flywheel to the pump...bam. Water cooled diesel PT425. The oil drain on the bottom of the engine lined up perfectly so my 19mm wrench can slip in and spill her guts.
Bellhousing $350, Kubota donor engine $500 <--that was unbelievable. Replacing the cover with Aluminum, $300. The cover replacement had nothing to do with the engine swap. I could have just built the back out 2.5" and called it a day...but as you likely gather, I hated that cover from day one...it weighs almost as much as me.
I'll post pics once cleaned up and dressed in the new cover. Oh and if there was a middle finger emoticon...I'd aim it squarely at Robin Subaru.
/ pt 425 engine alternatives #13
I'm ditching the steel engine cover .... I went to metalscut4u.com and ordered three aluminum cuts to enclose the sides and top/front.
That is thinking outside the box!
:D
:D
Nice work.
Probably not a power hit from my 22 hp robin, but I really want to step up a few hp, not stay here. Field mowing with the 22 hp takes longer then it should.
I finally got around to pulling the hydraulic pump out of my 425. Dragging my feet on this project has paid off.
As you may already know, the Robin EH72 engine has been discontinued. Power Trac now sells a conversion kit that allows you to drop in a Kohler CH730-3208 engine.
The kit costs about $300 and includes muffler with gaskets, heat shield, new mounting spacers with bolts, a fuel elbow, an oil drain elbow, pump adapter, and a pre-punched steel plate to convert the existing mounting plate in the tub of the machine. I have included a picture of the kit below.
The existing pump adapter on a Robin engine will not work because the engine side pilot (ie the flat part inside of the outer rim) of the adaptor is only 6 1/2" instead of 7".
As it turns out, my machine is one of about ten that was build with a spline connector between the engine and pump. Seeing how much heavier built mine is, I feel I got lucky. I have attached pictures of my pump adapter/spline connector next to the standard love joy style. Mine is on the right. The round housing portion of my adapter measures 4 1/2" across vs 3 1/2" across for the standard style. In addition, the ears to which the pump bolts to are 1" across vs 3/4" across on the standard style. The guys at Power Trac said they have sold 3 or 4 conversion kits so far and will now ask people to confirm which connector they have between the engine and pump. They happened to have an adapter for my connection style on the shelf and are sending it my way.
The other differences I see in the parts I received vs what I have is that the heat shield is about 1 1/2" taller and the pipe spacers used to mount the engine to the machine are about 1" deep.
The engine is on order and the pump is in the shop. I will snap a few photos when I start putting things back together.
/ pt 425 engine alternatives #16
Wow! That's a good price for the kit. Where did you end up getting the new engine?
I shopped on line and ended up ordering one from equipatron.com. It cost $ 1,526 total shipped to my door.
/ pt 425 engine alternatives #19
This is good news. Please take a lot of pictures. My engine needs oil added every one to two hours. Spark plugs get fouled every couple months.
/ pt 425 engine alternatives #20
I hoped that by now PT would not be using 90 degree elbow in the exhaust!
