SSQA Receiver tube atachment
/ SSQA Receiver tube atachment #1
truckdiagnostics
Central WI
7753 bobcat
Built this so that I could get low and under the tong when it is on the ground. Also don't have to grab the forks.
boxed in the pin hone
This should get you the length
the other one is at a 45 this one is at ?, think you could get away with another 45, I just matched what was on the bucket.
The handle/bar on the top is a must, its heavy and makes much easier to move around
Everything is powder coated.
/ SSQA Receiver tube atachment #2
Clever design and very easy to use! Powder coat looks nice!
/ SSQA Receiver tube atachment #4
Corners are an issue no matter what system you use. Look up Faraday cage effect. You have to kind of 'force' the powder in the corners.
/ SSQA Receiver tube atachment #5
Be careful when lifting heavier trailers. I have repaired/rebuilt 4 different ssqa's that have been twisted because to much force has been applied to one face. It really needs to span both side to prevent damage.
I hear you. Moving around empty trailers it should be fine. On the heavier stuff I use the ball in the forks
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2022 EZ-GO ELITE...
Location Info Please
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A61572)
2018 Caterpillar...
