Stop thinger on a YM2202
/ Stop thinger on a YM2202 #1
Pinkylabmouse
Trinity, Al
YM2202
I have an old YM2202. I am trying to get it to crank, I am not a mechanic, I am not much of a tinkerer. There is a push/pull cable? at the bottom of the dash, it says STOP. When I am trying to crank the tractor should this be pushed-in or pulled-out? AND what exactly does this thing do? Shuts off the fuel? Releases the compression?
/ Stop thinger on a YM2202 #3
You also have a compression release push/pull cable on the left hand side as you see in this picture. It should be pulled as you begin to crank the engine over and then pushed in after a few fast revolutions of the engine. Yanmar YM 222D | Tractor.BG
/ Stop thinger on a YM2202 #4
So which lever are you referring to? yoiu can bet Yanmar did not put "stop" on yuor gray market tractor, but a lot of guys mistakenly use the decomp lever to stop, That can ruin your engine.
/ Stop thinger on a YM2202 #5
He has an aftermarket Tractor Supply cable installed. It is red with a "stop" written on it.
OK, I pushed it in and the tractor is now sitting outside idling while I came in here to say thank you. I would have pulled the STOP thinger to crank and would have run the battery down.
Also, I have a hole for the T-Handle for the Pressure Release, but just a hole, no T-Handle, should this concern me?
Thanks again,
Yours in Christ,
Pinkylabmouse
/ Stop thinger on a YM2202 #7
Can you post a picture of the engine (top area)? It sounds like the metal rod is missing. Its not that crucial to have the decompression unless you operate your tractor in sub freezing conditions. I always start mine up without the use of it.
/ Stop thinger on a YM2202 #8
Thanks again,
Yours in Christ,
Pinkylabmouse
Probably not if you have a good battery and good starter and unless you have pretty cold weather when cranking,. Normde, the 02 series did have both kill cable and decompression cable.
/ Stop thinger on a YM2202 #9
I am aware of that, but so far he has not determined by his posts whether he is using the fuel lever or the decomp lever. (What does the lever actually do?) On both, with lever in, runs normally, out, will not start.
/ Stop thinger on a YM2202 #10
This is where the stop cable connects. Just how it is hooked up inside I don't know. Pretty sure it just closes the rack when pulled.
/ Stop thinger on a YM2202 #12
Stop cable would go in the front governor area. Decompression cable would go in the valve cover area.
Case skid steer wheels and tires (A63118)
Case skid steer...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2018 Land Rover 4WD SUV (A61569)
2018 Land Rover...
2016 Nissan Sentra Sedan (A61569)
2016 Nissan Sentra...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
