3-Point Hitch 3-Point Question
/ 3-Point Question #1
Hammer Head
Lock Haven, PA
Kubota L3800 HST, Scag Tiger Cat
My son rented a post hole auger to use on my L3800 to speed up his deck project. He called me and asked how do you apply down pressure to the 3-Point?
I replied, I am not sure. The only thing I have used other than my BH77 is a York Rake. I was pretty sure the knob under the seat is only a speed control?
He did finish however I thought I would ask the question for future use. Can anyone help?
Thanks in advance.
Jeff
/ 3-Point Question #2
Unless you have one of the few tractors with down pressure in the 3 point there is likely no down pressure on your tractor's hitch.
/ 3-Point Question #3
Weight and gravity for most tractors
/ 3-Point Question #4
Agreed, Weight and gravity. The only tractors I know of with Downward 3 point hitch pressure is Belarus from Eastern Europe. It is a nice feature for certain applications. He may want to try applying some ballast to the auger, sometimes, depending on soil conditions just a gallon of water can make a huge difference if there is perhaps a layer of clay hardpan etc.
Cheers
Roger
/ 3-Point Question #5
Agreed with the others that most don't have it. Once exception to the rule is some of the newest JD if they were ordered with the option.
There is however, an option available for some post hole augers to have an additional cyl on the PHD itself that will apply up to 500 lbs of downpressure. I don't imagine many of the rental units have this option.
Down pressure and additional control is why augers are SOOOO much nicer when run on a skid steer or mini-ex
/ 3-Point Question #6
I built a platform for a 200lbs chunk of pipe over the gearbox on my PHD.
Also rebuilt it so it attaches to my quick hitch (only works if you have a hydraulic toplink). The toplink will lift the back end off the ground for the first foot or so of the hole or so if you were stupid enough to balance the tractor on the auger & front axle pivot.
Generally you just rely on good teeth on the auger to dig in.
/ 3-Point Question #7
Every time I add down pressure in the form of weight to my PHD I start busting shear pins...it did come from TSC but still.
/ 3-Point Question #8
Yea, looks like everyone covered this one pretty quick. - Not just Kubota here but with the majority of all tractor makes & models will the 3pt hitch only be gravity driven w/o any downforce other than the weight of the implement hooked up to it.
You still have a couple options here to consider to help gain an advantage over harder ground & get a better bite.
-A) Since this is so obvious I'll list it first just for others who may read this that own their tractor & do not know about this. It may be helpful. - There is a "dealer installed option" for a number of models that Kubota calls a "Top'N'Tilt Kit" which replaces 1 of the Lift Rods & the top link for ones that are hydraulically controlled via rear remotes (which also must either be already equipped or purchased as well).
Now this is a rental tractor at the center of this situation so again, this is not a practical fix for you guys here.
-B) With a rental here's where I'd start: take a good look at the teeth on the auger that the rental company sent it out with. Sometimes these either get often overlooked or just don't get inspected at all upon return of their rental. If it's not digging well or very slow then there's a good chance that the teeth are very worn & need replaced. - Speak to your rental company about this matter.
-C) You should have the option either w/ the rental and/or dealer to shell out a few extra dollars if need be to "upgrade" to a carbide tipped tooth or to an auger already fitted w/ carbide teeth. These teeth are much much stronger than the standard teeth, last much longer all while keeping a sharper edge. You may also ask about teeth with a more aggressive angle of attack. Many come w/ between a 30-40 degree attack, there are some with a 50-60 degree attack, & even some w/ 40 degrees mounted one direction & if flipped over it offers a 50 degree attack.
-D) just a couple last few tips that may be on the table for consideration (depending on your own situation, what the work area looks like or will allow, etc.)
- flood a hole hole w/ water that starts to become hard to drill through. This may help soften the ground but most importantly it will help keep friction down & slow the wear on your teeth.
- find a way to safely add weight over the top of the main top arm of the auger drive head. (Humans not recommended to be stand-ins for sandbags, etc. lol ;)
/ 3-Point Question #9
Hate to be the "safety police", but it's worth mentioning again the blindingly obvous danger of jumping on or manually pushing down on the auger to add downforce. Watched a guy do that once in frustration before anyone could stop him. Thankfully he got away with it... at least that time, but one slip puts you in the auger.
/ 3-Point Question #10
Just for the record our old 1954 Massey Harris Pacer has both up and down force on the hydraulics. That feature was used for a wide variety of things but only rarely to force an implement downward. The worst of it was those tractors had no 3 pt hitch.
/ 3-Point Question #11
I'm confused. What was the down force on if your Massey didn't have 3pt hitch?
/ 3-Point Question #12
It's possible to put down-force on a PHD by putting a brace between the ROPS and the boom and using the FEL to lift the front of the tractor. It seems like something from the Red Green show on Canadian TV, but works in some situations like getting started in hard pan. There's a risk of wrecking something so all the usual cautions, warnings, etc. apply.
/ 3-Point Question #13
!! WARNING !! NEVER USE YOUR ROPS FOR THIS!
You should never use your ROPS in this way. You should also never drill through, weld on, grind, or make any sort of changes to or with your ROPS.
- You can safely use your ROPS to CLAMP things onto such as a small toolbox, lights, & other smaller accessories.
/ 3-Point Question #14
The double acting hydraulic cylinder would force a cast iron lever on a shaft either clockwise or counterclockwise. Depending on what you had connected to it, it would provide force either direction. Over the years examples included downward force on a disk harrow, upward cable connected pull or lift on a "buck rake" used to move loose hay and hay shocks, downward force on a potato plow that kept it engaged in the soil independent of gravity, etc. The biggest pain was the lack of a "standardized" 3pt hitch and thus no compatibility with a wide variety of implements. That did not mean there was no hitch for various implements. BY THE WAY this tractor was made in Canada and still runs really well today at age 62.
/ 3-Point Question #15
Belarus is the only 3pt hitch tractor I can think of that has down pressure.
IH tractors with 2 pt hitch (and thus 3pt adaptor) had down pressure as well.
/ 3-Point Question #16
Some skip loader tractors have down pressure. My JCB for example has an external double acting cylinder that controls the 3 point. It's really nice for some situations.
/ 3-Point Question #17
Mr. Roadhunter: I think it is a profound change in the Ag equipment market -- to see skid-steer technology spread over into Ag equipment. Amazes me how long it takes ! Putting skid-steer compatible plates on the front of front-end loader frames was so obvious it is just crazy. But look how long it took. Kubota quietly transitioned over to standardizing on the interface for the FEL buckets starting around 10 years ago. Other brands have been head scratchers in still not standardizing on the skid-steer interface for the FEL buckets. The main underpinning of value to farmers and the AG industry is MASS MARKET. There have to be 50 times as many implements sold nation-wide for skid-steers than for AG tractors. That means so many things in terms of driving prices down. It also means hundreds of implements potentially useful on your tractor compared to the teens of implements otherwise. I had not heard of the JCB up/down force feature for their 3pt hitches. But it doesn't surprise me. I'm guessing there are many, many other features and devices in use on skid-steers with no good excuse for failure to make them available for farm tractors too. THE SECRET is standardization of the connections. The interface. Skid-steer compatibility is second only to the 3pt hitch in AG tractor evolutionary milestones.
/ 3-Point Question #18
I think old timers who have been making the decisions tend to be of the line of thinking that tractors are meant to pull and skid steers are meant to push and lift.
/ 3-Point Question
Thanks for the good information. the issue was the worn cutting surface on the auger. The auger teeth were shot as most of you thought.
So much for rented equipment!
/ 3-Point Question #20
OVRxNxOUT how is top n tilt going to help on a post hole digger
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2025 IREAS Grid-Shaped Rock Bucket Mini Excavator Attachment (A61572)
2025 IREAS...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
