Ford 4610 Lift arms leak down
   / Ford 4610 Lift arms leak down #1
Blaze08
Member
Ga
Mahindra 4530/Ford 4610
As the title states the lift or pick up arms will leak down and you aren't able to set at a constant height. Any thoughts?
Anyone?
   / Ford 4610 Lift arms leak down #3
Are they leaking down while running or while parked?
   / Ford 4610 Lift arms leak down #5
Have you checked fluid level?
Yes...
   / Ford 4610 Lift arms leak down #7
Do you have remotes where you can check pressure with a gauge?
   / Ford 4610 Lift arms leak down #8
I'm not much help with hydraulics, there are more knowledgeable members I'm hoping might chime in.
   / Ford 4610 Lift arms leak down #10
Does the 3pt jump as in it's trying to maintain a certain height, this would be a leak in the lift cylinder.
Or, you can't set the position of the implement and when you try, it falls all the way down or raises all the up. If this is the case, then you are using the draft lever, the one on the inside of the quadrant OR you have a problem with your linkage. You could also check to see it the top link draft yoke has slop in it. That's the one with the big spring on the top of the axle housing.
I'm going to update this....the draft lever is the only one that works. The other one doesn't work.
   / Ford 4610 Lift arms leak down #12
Sounds like the cylinder is scored and perhaps you also have a control valve issue. Any water in the oil?
If not you need to remove the top cover to investigate, the cylinder is bolted to the top cover and can be replaced. There are later styles depending on the one you already have.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
Case 950 8 Row Air Planter (A56438)
Case 950 8 Row Air...
