8 foot back blade too much?
/ 8 foot back blade too much? #21
Here's a pic, it looks like they take a pin and the opening is 2 1/2 inchesView attachment 463005
Yep. That's how my KK is built. When searching for scarifier teeth you need ones with holes drilled in them for the pin. Make sure the width and thickness of the teeth will fit your BB. Then you need to buy or build some pins. KK uses a similar pin to what holds a hitch receiver in the tube, but shorter. Anything you can rig up will work.
Here is what I am looking at Agri Supply, it looks like they will work. They also have the pins.
Agmate(R) Box Blade Shank, 18 In. Long, 4 Hole
/ 8 foot back blade too much? #23
Yep, looks like they would work.
/ 8 foot back blade too much? #24
I never used an 8' blade on my R4047H, but I will say that with heavy snow an 8' blade is at the limits of my Massey. You'll likely have better luck because you have 4wd, and the weight from the loader on the front. I've been meaning to make a couple of front weights to fit my weight bracket, but haven't gotten around to it....it's on the list!
/ 8 foot back blade too much? #26
Cool. Post the results with pics when you get them.
I got the scarifiers and they fit
perfect. I still have the backhoe hooked up so haven't had a chance to try it out. Snowed here yesterday so everything is a little muddy still. I hope to try it out Saturday. uploadfromtaptalk1460318225814.jpg
/ 8 foot back blade too much? #29
Lookin good.
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
Golf Cart (pictures to come) (A62679)
Golf Cart...
