8 foot back blade too much?
/ 8 foot back blade too much? #21
Here's a pic, it looks like they take a pin and the opening is 2 1/2 inchesView attachment 463005
Yep. That's how my KK is built. When searching for scarifier teeth you need ones with holes drilled in them for the pin. Make sure the width and thickness of the teeth will fit your BB. Then you need to buy or build some pins. KK uses a similar pin to what holds a hitch receiver in the tube, but shorter. Anything you can rig up will work.
Here is what I am looking at Agri Supply, it looks like they will work. They also have the pins.
Agmate(R) Box Blade Shank, 18 In. Long, 4 Hole
/ 8 foot back blade too much? #23
Yep, looks like they would work.
/ 8 foot back blade too much? #24
I never used an 8' blade on my R4047H, but I will say that with heavy snow an 8' blade is at the limits of my Massey. You'll likely have better luck because you have 4wd, and the weight from the loader on the front. I've been meaning to make a couple of front weights to fit my weight bracket, but haven't gotten around to it....it's on the list!
/ 8 foot back blade too much? #26
Cool. Post the results with pics when you get them.
I got the scarifiers and they fit
perfect. I still have the backhoe hooked up so haven't had a chance to try it out. Snowed here yesterday so everything is a little muddy still. I hope to try it out Saturday. uploadfromtaptalk1460318225814.jpg
/ 8 foot back blade too much? #29
Lookin good.
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
Crane Carriage System for Steel Baskets (A65579)
Crane Carriage...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
Skeleton Backing Plate (A62679)
Skeleton Backing...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
