Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,317
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Awhile back I removed an old worn out trailer jack and replaced it with this new 8,000 lb jack. I put it in the same place as the old one was. I didn't think about it at the time ----- but quickly discovered that my tailgate would impact the jack if not very careful to set it down on a rag.
Had enough after a couple years of this silliness and decided to move the jack rearward.
Here's the tailgate resting on the jack, on a glove. I am very tired of doing this. I suppose tailgates are longer than they used to be.
Cut out the jack with a thin cutoff wheel.
Filled the wound.
Welded with 120v MIG. I used 1/8" thickness settings to avoid popping the house 15A breaker. Breaker didn't pop. That top plate is 3/16", the patches are 1/8".
All evils erased....hidden from the amateur weld inspectors! :laughing:
Re-mounted jack rearward. Welded the "root" uphill, then covered over going downhill. Added a little corner gusset.
Now tailgate clears.
Wonder of wonders. I can now simply open the tailgate to get chains out etc.
Filled the wound.
