Moved trailer jack (so tailgate doesn't hit it)
/ Moved trailer jack (so tailgate doesn't hit it) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Awhile back I removed an old worn out trailer jack and replaced it with this new 8,000 lb jack. I put it in the same place as the old one was. I didn't think about it at the time ----- but quickly discovered that my tailgate would impact the jack if not very careful to set it down on a rag.
Had enough after a couple years of this silliness and decided to move the jack rearward.
462910d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Here's the tailgate resting on the jack, on a glove. I am very tired of doing this. I suppose tailgates are longer than they used to be.
462911d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Cut out the jack with a thin cutoff wheel.
462912d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Filled the wound.
462913d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Welded with 120v MIG. I used 1/8" thickness settings to avoid popping the house 15A breaker. Breaker didn't pop. That top plate is 3/16", the patches are 1/8".
462914d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
All evils erased....hidden from the amateur weld inspectors! :laughing:
462915d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Re-mounted jack rearward. Welded the "root" uphill, then covered over going downhill. Added a little corner gusset.
462916d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Now tailgate clears.
462917d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
Wonder of wonders. I can now simply open the tailgate to get chains out etc.
462918d1459293645-moved-trailer-jack-so-tailgate-img_4020-jpg
/ Moved trailer jack (so tailgate doesn't hit it) #2
Looks good - dunno if it's just viewing angle, but I'm thinkin' you'll only crank the jack up/down ONCE with it hitched up and the tailgate down :D ...Steve
/ Moved trailer jack (so tailgate doesn't hit it) #3
I'm kind of surprised you didn't put a cutout in the tailgate so you could do some more tiggin'.
Terry
/ Moved trailer jack (so tailgate doesn't hit it) #4
Looks good! Don't forget to put the tailgate back up before moving it:shocked:
Our horse trailer jack just clears my tailgate. My mother in laws horse trailer doesn't... sometimes I almost forget.
Chris
/ Moved trailer jack (so tailgate doesn't hit it) #5
Terry
The other option is to "Bob" the bed, but leave the frame stock length. Six of that, half a dozen of the other.
Chris
/ Moved trailer jack (so tailgate doesn't hit it) #6
Nice looking welds! You get along well with your 120v mig.
/ Moved trailer jack (so tailgate doesn't hit it) #7
I know I'm the last person on earth you will ever take welding advice from.
That downhill vertical Mig welding on anything structural is going to bite you in the a $ $ one of these days!:eek:
/ Moved trailer jack (so tailgate doesn't hit it) #8
First thing I did when I got my car trailer was to remove the tongue jack and replace it with a clamp on swivel jack.
Much nicer having it stowed flat.
SA I do take advice from you and am very thankful for it. Many that I use every day and I'm a better welder for it. But luckily I have the experience to be able to pick and choose what's useful.
I tend to disagree with your advice when you post "half advice" - leaving a big hole in what newbie members could have learned from the example. They don't know enough yet to recognize that the advice is incomplete, and that they shouldn't YET commit it to memory. I understand you're not paid for complete advice, but ( I think) you should understand your newbie members will think it's "complete", and in that case, is partially "wrong".
Unfortunately I somehow feel responsibility to tractor members when I see this, and that's when we've butted keyboards (in the past). And then you duck out by posting a pic of a 2" thick weld on a bridge and everyone goes ga-ga for a moment and the original teachable moment is lost. Or some other diversion. This is precisely when the experienced welder on-board should STAY focused (IMHO). The newbies who were following the example, and wanted to understand and learn ---- get the shaft.
I'd like to see (considering this is a tractor sub-forum) that discussion remains geared toward how the tractor owner might use the welding information. But that's just me, I like to see members learn stuff. I like to see their projects, and their progression and their successes. More projects = more practice = more learning = more projects. I don't like to see members get the message that they will never get anywhere if they don't have pro experience, that's hogwash. Or that welding good enough..... is never good enough. But of course you fellas can do the forum however you want!
First thing I did when I got my car trailer was to remove the tongue jack and replace it with a clamp on swivel jack. Much nicer having it stowed flat.
I probably should have cut that truck-receiver upside-down winch mount off and rebuilt it more sensibly, and considered a swivel jack. But not sure I'd want a swivel jack on this trailer....I don't like the movement (when loading eqpt). I do like swivel jacks on OTHER trailers. Too many other jobs on the to do list - I need to pick and choose the quicker job at times.
/ Moved trailer jack (so tailgate doesn't hit it) #10
Ditto. However I bought the weld on one with the round pipe. Now I can pull the pin and stow it. Plans are to buy more of the weld on pipes so I can move it to the back to use as anti-tip downriggers. Of course then I need 2 jacks for the car trailer. My brother has 2 jacks like this on his pickup box trailer so that it won't tip up when loading and it is unhooked.
/ Moved trailer jack (so tailgate doesn't hit it) #11
That upside down receiver hitch is an idea I might use... I have a hitch that I could repurpose and have a nice winch mount perhaps..
I would just buy a receiver from Harbor Freight for $15. It only has to hold the winch and can be much more compact than that big ole' thing. Of course using what you HAVE on hand is sensible too, if you wait you take the loss of "non-use".
/ Moved trailer jack (so tailgate doesn't hit it) #13
Even though the jack is moved you still need to keep I mind to not drive with the tailgate down. My trailer jack is In The same place as your new location and I was driving across the yard to park after unloading stuff. I left the tailgate down and when making a turn the jack made a nice jack shaped crease about two inches deep in the tailgate corner.
That sounds like something I'd do. Thx for the reminder.
/ Moved trailer jack (so tailgate doesn't hit it) #15
I like those too. U can also use them to change a flat if they're mounted behind the axle.
/ Moved trailer jack (so tailgate doesn't hit it) #16
Not finding fault with your method but sharing mine. My clamp on moved the jack just far enough away to clear the tailgate and the swivel makes it easy to stow without having to retract it all the way up.
JD your whole project looks like the easier way. I was focused on what was there, kinda forgot about the benefits of the fold up kind. I coulda built that connection onto my jack easily. Wheel is a blessing & curse ( but if it had a reliable brake....) :thumbsup:
/ Moved trailer jack (so tailgate doesn't hit it) #18
newtrailerpics003.jpgI like the way the jack on my trailer is mounted. It has a telescoping foot that is spring loaded to retract it so you only have to jack it up enough to release pressure on it when hitching then pull the pin to retract the foot. Reverse order when unhooking so there is less turning of the crank handle. There is no way to hit the tailgate on it, but with center mounting as it is, you would need to offset a winch a bit.
/ Moved trailer jack (so tailgate doesn't hit it) #19
I have installed a Jack-E-Up on every trailer I have or will ever have. In fact I just installed one on my Son's trailer last weekend. These are wonderful, they allow you to completely remove the jack with just a third of a rotation of the jack.
That guy modified his trailer (extended the tongue a foot). I bet he's kicking himself like me. He could have easily moved the jack rearward at the time to allow for modern 2-foot tailgates.
1720 I couldn't have a separable jack - or it's gone. In a pickup 100 miles from the trailer. Or on the wrong trailer. For me the jack has to be welded/bolted/cabled/chained/pinned to the trailer like a ball&chain.
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
6 ROW RIPPER BEDDER W/ROW MARKERS, 3PT (A62130)
6 ROW RIPPER...
