Generator to power electronics?
/ Generator to power electronics? #1
jymbee
Upstate, NY
Massey 1652, 1949 Farmall H
We expect to be doing some demos this summer and many of these sites will be outdoors with no AC power. I'd like to use our Honda generator to power a notebook computer, 23" monitor & Dye Sub printer. I believe the power output of this generator would be sufficient (?) to run the equiipment, but wondering if there's something we might want to do between the generator and the electronics by way of protection? Perhaps a power surge device of some kind or is there something more suitable for this kind of application?
/ Generator to power electronics? #2
IMHO I think a Honda inverter generator and a surge protector and you should be good to go.
/ Generator to power electronics? #3
As long as your load isn't too close to the generator capacity you should be OK. Just get a good high quality surge suppressor plug strip to go along with it.
/ Generator to power electronics? #4
I used to have a 4.4 kw Suzuki generator and used my computers on it.
Ralph
/ Generator to power electronics? #5
We have and use that very same Honda generator. Although we use it for construction power, not computers. Gee, we do love this little generator. Seems this machine was made to be safety used with sensitive electronics, like your computer.
/ Generator to power electronics? #6
What you are looking for is a device called a line conditioner or power conditioner.
/ Generator to power electronics? #7
I have a 5.6kw Wacker Generator and I used it to power my house including TV, Satellite and computer for 12 days during a hurricane close call. I had no issues that whole time.
I only shut the gen down twice a day to refuel.
I bought one of the Honda EU 2000 gens a year ago for use around my new property and I love it. Portable and quiet!
/ Generator to power electronics? #8
I'd be inclined to run your Honda inverter gen as is - they are well regulated. I am assuming that your printer is not a power hog - add up the sticker wattages of what you are using, and/or test with a KillAWatt meter.
Honda makes a good generator, but the other reason I would go that way is it is possible that some forms of down-stream protection might interfere with how the generator "sees" the load, causing it to mis-behave.... worth checking with Honda tech support, if nothing is mentioned in the manual.
Rgds, D.
/ Generator to power electronics? #9
I would try and avoid having electronics on line during start up and shut down if at all possible.
/ Generator to power electronics? #10
You will want to run the electronics off of a UPS such as the APC BR1500G Back-UPS*Pro which offers AVR (Automatic Voltage Regulation) to help handle spikes and drops in the generator power.
Aaron Z
/ Generator to power electronics? #11
I also would be concerned about when a big load started or stopped.
This comes down to how good the voltage regulation is on the generator. Guessing beter generators have better ones. You could ask manufacturer of generator, or better yet of a laptop. Could probaby google this too.
You could charge an old car battery or tractor, and charge with that. I have probably ran my computer off a jobsite that was powered by generator, but not for long periods.
/ Generator to power electronics? #12
Always good practice.
The first small gen I bought recommended running it totally unloaded for 2 minutes before connecting the loads, and after removing the load before shutdown, continuing to run it unloaded for 2 minutes again. Easy enough to do, so that's what I've followed with all gens I've run since, unless they recommend longer times.
Rgds, D.
/ Generator to power electronics? #13
If really nervous . There are those 1:1 isolation transformers rated at 120V and 1500VA. Add 25mfd of oil filled run capacitor on the generator side and good to go.
/ Generator to power electronics? #14
Most of the time, if you have an external power supply, you should be fine if you let the generator get up and running before plugging anything in.
/ Generator to power electronics? #15
Aaron Z
I agree. A UPS between the generator and the electronics is the way to go.
/ Generator to power electronics? #16
While the Honda generators are some of the cleanest waveform wise, and quietest audio wise, a good UPS in between will do no harm and be useful while refueling also. Your laptop might draw 65 watts, sure isn't going to load down even a 1000 watt honda. Add up all the loads watts and you will get an idea of load vs time. Here is a good one that I have on my Television and audio equipment.
Amazon.com: APC BR1G Back-UPS Pro 8-outlet Uninterruptible Power Supply (UPS): Electronics
/ Generator to power electronics? #17
We use laptops and projectors on honda generators, not a problem.
/ Generator to power electronics? #18
Yep, they are a first choice or a lot of Amateur radio operators as well, and those electronics are often a lot more expensive than what most people might put on them .:)
