Power Trac Parts Cross Reference Thread
/ Power Trac Parts Cross Reference Thread #22
I will add that one of our forum members lives on eBay and has sent me numerous links to filter deals. I bought a dozen hydraulics for the price of two. Generally they come from machine shops gone out of business.
/ Power Trac Parts Cross Reference Thread #23
Anyone using the wix/Napa hydraulic filters on 425? IThe specs on the wix/Napa filters do not indicate they are rated for suction. ???
I will have to look up my # and let you know I believe the prefix is the suction part and sufix is the micron rating.
/ Power Trac Parts Cross Reference Thread #25
Good...I'll work my Google fu for some deals. I like having one or two for back-up.
/ Power Trac Parts Cross Reference Thread #27
Can anyone shed some light on what the larger fittings are for the 14XX and 18XX?
I'm guessing that they are Stucchi IRV series, specifically, (820001022?), IR34V FA for the larger PTO fittings. Has anyone cross matched the large drain fitting? BIR12 (800501005?)
All the best,
Peter
/ Power Trac Parts Cross Reference Thread #28
Are you referring to the coupler? Tell you what I learned, I couldn't find them. I spent a week hunting around at the biggest Hydraulic stores in the area. Eventually ponied up and bought Parker. They seem pretty universal compared to that weird Italian stuff that makes no sense for PT to purchase.
Venting, sorry not much more help.
/ Power Trac Parts Cross Reference Thread #29
Well in Power-Trac's defense, after browsing around on lots of specification sheets, I did notice that weird as they are, they seem to be the only couplers rated for more than 3000psi, that aren't the monstrously expensive 10,000psi couplers. I think that they are an ISO 5675 poppet connector.
Oh, and according to the charts, the 1/2" ones cross reference to the ISO7241-1 Series A (Parker 6600), but only the 1/2" ones.
http://www.stucchiusa.com/PDF/10_IR_IRV_IRS.pdf
All the best,
Peter
/ Power Trac Parts Cross Reference Thread #31
Update: The Stucchi fittings are a cross match to a Faster NV series.
The 1/2" is a standard ISO. The Stucchi number is M.BIR 12 NPT, part # 800501005. (The female is 800501004.)
On my 1445, it is used for the case drain, or for the return from the post driver. These cross reference to Parker 6600, Faster ANV ISO A.
The PTO connectors are a Stucchi “IR 34V FA NPT” pair, these are Stucchi’s Faster interchange series. I spoke to Ray at Stucchi, who said that the part number should be 820001022, and 820001023. I believe that the Faster part # is NV 34 NPT F or NV 34 NPT M. These are not ISO.
The key letters here for Stucchi are the "FA" which is for their Faster interchange. Without it, the IR series are 2mm too large. Don't ask how I know.:mad:
In stock by a number of vendors, once you have the part numbers...
All the best,
Peter
All the best,
Peter
Hey, I made this thread a sticky, so it stays at the top of the forum for easier reference. Anyone object to that?
/ Power Trac Parts Cross Reference Thread #33
Anyone know what aftermarket Spal (or other brand) fan fits a PT-425. I've replaced mine once, ordering from Tazewell, but need to replace it again and hope to save a few bucks. TIA.
/ Power Trac Parts Cross Reference Thread #34
There should be numbers all over it (There are on mine) Do you have the diameter? Depth? Its pretty easy to source out.
/ Power Trac Parts Cross Reference Thread #35
PT 1850 Additional Info
Cooling Fan = Spahl 30100385
Oil Temp Sensor = VDO 323-121
Tram Pump - Bondioli M4-PV
Wheel Motors - White 6 cu In
Paint - Red = Rustoleum Machine Red
Black - Rustoleum FLat Black
/ Power Trac Parts Cross Reference Thread #36
Uh, I don't think slope mowers have a 6ci wheel motor. (1430s have an 18.x ci).
/ Power Trac Parts Cross Reference Thread #38
Order one directly from Spal. Got info from old fan, went to their website and found same model, then ordered. Think it was around $75, but that was 4-5 years ago.
/ Power Trac Parts Cross Reference Thread #39
Looking for new rubber dust cap and plug for PT-422 quick connect hydraulic fittings. Will any 1/2" cap and plug work?
Thanks
Frank
Not sure. Tractor Supply lists them on their websites for about $4.00. They have plugs and caps in red and black.
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
2011 International 4300 Versalift Bucket Truck (A64194)
2011 International...
