Been working on a mill.
/ Been working on a mill. #21
We will know soon, I moved a nice pine log over to the mill yesterday. lol
SR
/ Been working on a mill. #22
You guys are making me want something I don't need. I do have several large piles of live oaks to cut up and burn. HMMMMMMM!
/ Been working on a mill. #23
I worked on the only "breakage" I've had in a long time, yesterday... lol
The T-handle that holds a log post on my mill got broken off, leaving the end of it in a bolt hole. It's an old break that wasn't taken care of long ago, as I don't use that log post often. But, I'm about to, as I'm changing some things around on my mill.
Anyway, here's what I used to help get it out, and I have to say, if you never have used any "Tap Magic", you need to get some! It's absolutely the best tapping/drilling fluid I've ever used!
Anyway, time to drill a hole in that broken off part,
And tap an "easy out" into the hole,
and turn the easy out "out" with a wrench,
AND here's what it looks like, all "fixed",
Once I get done making some changes on the mill, i'll be up and running it, as I need to mill out some "battens" for an unfinished board and batten "siding" project I have going on...
SR
Rob, Looks like a good fix. Maybe you can show some of that board and batten you're working on.
That where I am on my mill, I need to make log dogs and stops.But I couldn't resist making some sawdust.
Rob,What's the diameter of your log stops, in the picture they look pretty good size.
Richard
/ Been working on a mill. #27
Here's what the battens are going on, I didn't get to them last fall...
SR
/ Been working on a mill. #28
Been there done that, been planning a mill build for a few years now. One day, maybe
I've been planning to build a mill and accumulating materials for around 30 years. I hope to get it done in time to saw the lumber for my coffin.
/ Been working on a mill. #29
Made a couple extra log posts for my mill so here's a pic. to give you an alternative idea.
I think it's 1.25" tubing. It can be flipped around to still hold when sawing down to 1" material.
Billrog, I'd like to see the other dogs the, the ones that tighten to the log.
Richard
/ Been working on a mill. #31
Richard I'll see if I can find some you can visualize and if they interest you I'll get the measurements of the material sizes.
Out of hundreds of mill pics. I don't seem to have many of the dogs check through the pics. in Photo bucket there may be more. Mean while I can take some descent pics. if you like.
Cheers Bill
/ Been working on a mill. #32
Neat stuff. I have a side question.
Can any of you sawyers recommend a type of wood to go on top of the piers under my double wide? They used pine about 12 years ago and they are dilapidated.
I have access to some fresh sawn cedar wood. Would that work?
Thanks in advance.
/ Been working on a mill. #33
Thanks in advance.
Cedar is soft, and may compress. I would use locust or white oak. Quite rot resistant, and hard.
/ Been working on a mill. #34
Like mentioned cedar may compress & I'm not familiar enough with what's available where you live to give advice. For cedar to work it would have to have very tight growth rings and that's not very common.
Greetings, I used square tubing I had, just bought some that it would slide into. I tacked them a bit too close to the guide, not sure if I should grind them off and move them over or use a 1 by to space the log or CANT.
I like the way your stops and dogs are made, just swing up and down.
Kyle, i've used Doug Fir in many places, it's strong and wants to last forever.
Some years I asked you about that:Come and take It motto. You gave me a brief description and I looked it up, Great story, told it often.
Richard
Richard
/ Been working on a mill. #37
Richard
Richard
Thank you, the motto has gained significance in the last 2 terms.
/ Been working on a mill. #38
I think you may be happy if you move the log posts in just far enough to clear the band wheel for sawing higher cants. The stationary posts are will be more stable and accurate than ones that swing.
/ Been working on a mill. #39
Valley this would be a useful mode to your mill could save you from sawing off a log post. Look in the pic. the 90 degree bent rod that sits in front of the blade guide roller. Sits just ahead of the blade and will stop the saw before you run into a post if you forget to lower it.
Billrog, I like that, in the picture above, I'll try to do something like that. Just looked at the dogs in your photo, that's what I'm thinking, may use round stock so the gard will be pushed down or stop the carriage.
Is the cross rod on your mill, the ones the dogs slide on solid or like 3/4" plumbing pipe?
