B7100 & Pat's Easy Change
/ B7100 & Pat's Easy Change #1
masscity
NW UP of Michigan
L3540HSTC-3 B7100DT Ferguson TO-35
Has anybody tried using Pat's Easy Change on a B7100DT? I bought it new in 1979. I'm hoping they will work, because I'm getting tired of hooking up my box blade and
mower. I know I'll have to buy a longer top link too.
Hooking anything to my 3ph on my L3540 is a piece of cake compared to the B7100. I'm 69 years old and have chronic pancreatitis making hard for me to bend down.
Thanks
/ B7100 & Pat's Easy Change #2
I put them on my 1983 B7100 and like them. I had tried a quick hitch but most things I have didn't fit. My neighbor bought me the Pat's and have had them on since. If you don't get the piece that holds the width you could make it. I'm not sure I changed the top link or not. Or maybe I had already changed it. Was worried about the length of PTO shafts on mowers but they were still long enough.
I think you will like Pat's and it fit fine.
Dan
Dan
Do your lower arms have all the bends in them. The one that concerns me is the last bend close to the ball. I think I read somewhere that Pat's needs two inches of room at the end to work. Mine would be close for the two inches.
I'll probably buy the stabilizer bar even though as you said I could make one.
Thanks for the help.
/ B7100 & Pat's Easy Change #4
The product is fine but do not buy from Pats website because the return policy is a joke, no spacer bar, plus you will pay about $60 more than if you bought from Rural King or another web site. Even Amazon is a lot less.
/ B7100 & Pat's Easy Change #5
I got the stabilizer with mine. It's just pretty simple.
The Pat's fit on the ends OK. Might be better that it's a tight fit. I think I had them installed in 15 minutes.I may try and take a picture tomorrow morning for you. This is on a 1983 B7100. I also have a 1993 and think the 3 point is the same. Only difference I've noticed on the newer one is they changed the front hub to 6 lug.
I would appreciate it if you could show a picture, that would help a lot. Since yours fit I'm pretty sure mine will fit too.
Thanks CStone for the info on returning etc. I'll do a search and see where would be the lowest price to buy.
I'm not in a hurry to get it, still snow, wet and muddy up here even though we had a mild winter.
Thanks
Ed
/ B7100 & Pat's Easy Change #7
Going to try to add pictures. Here goes.
/ B7100 & Pat's Easy Change #8
That was easy this time. Here are some pictures of the stabilizer. It's only really used to aid in hook up. With a PTO you need to remove it or you will bend it.
/ B7100 & Pat's Easy Change #11
Your right about the lift arms being different. On both my B7100's they are straight with bends only on the ends. I thought the bend at the end is what you were concerned with. I don't think the design of yours would be a problem. I'll have to think about it some more. Here's a picture of mine.
The reason for the green paint it was bought by a Deere employee that painted it John Deere Green one month after it was bought NEW. I have all his purchasing info and he was looking at Deere's and others before getting the Kubota. We call it a Kudeere.
/ B7100 & Pat's Easy Change #12
You will have to learn to put up a picture. I'm impressed with a one owner compact tractor of that vintage. I think they discontinued the B7100. Then brought it back because of demand. I Wish Deere would do that with the 318 and 455.
I went around Lake Superior a few years back looking at waterfalls. Took four days to get across Michigan UP. Felt like most was on gravel. I want to go back to Grand Marais for breakfast (West Bay Diner).
The bend at the end is what concerns me. I think I have 2" or less on my arms after the bend. How far is from the middle of Pat's pin where it attaches to the lower link ball to the tractor end of Pat's?
I did a motorcycle trip around Lake Superior with my buddies in 1999.
I bought my B7100 in July 1979 in the Detroit area. My boss was good friends with the tractor dealer and got me $500 off. I paid less than the tractor salesman and he wasn't happy. I went to California and back in 1982, but my Dad and brothers used it from 1984 to 2006 when I moved back to the UP and retired. I was offered $5000 from three different people as early as 1986, but I wouldn't sell it. I thought I might need it down the road and I knew the prices kept going up.
Thanks
Ed
/ B7100 & Pat's Easy Change #14
Thanks
Ed
You don't seem to have gotten a reply so I went out and measured mine. Center of the pin to the back of the U bolt that helps stabilize it is 2 1/8" However the slot at the back is 1 1/2" wide so there is room for a little bend in the arm. Mine is a category 1. If that is what you need you can get it on ebay from Radcliff electric for $169.00 with the stabilizer bar and free shipping. That was the cheapest I found it. Since my tiller has cat 0 spacing with cat 1 pins I had to cut 2" off the inner bar on the stabilizer to get it narrow enough. one of the best accessories I have bought for the tractor yet.
You don't seem to have gotten a reply so I went out and measured mine. Center of the pin to the back of the U bolt that helps stabilize it is 2 1/8" However the slot at the back is 1 1/2" wide so there is room for a little bend in the arm. Mine is a category 1. If that is what you need you can get it on ebay from Radcliff electric for $169.00 with the stabilizer bar and free shipping. That was the cheapest I found it. Since my tiller has cat 0 spacing with cat 1 pins I had to cut 2" off the inner bar on the stabilizer to get it narrow enough. one of the best accessories I have bought for the tractor yet.[/QUOTE
Thanks for the reply. Earlier I didn't get a reply so I bought it anyways and it works fine. My PTO shaft on my RM-48 is still long enough too.
I had to buy a longer top link for my box blade so I can tip it back enough. Sure makes hooking up my equipment easy now.
Ed
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
MILITARY STYLE S/A CARGO TRAILER (A63291)
MILITARY STYLE S/A...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
