Replacing the ball in top/lower links
/ Replacing the ball in top/lower links #1
bjorn773
Roscoe, IL
Kubota L2250
I notice my local Farm & Fleet has replacement balls for the links on the 3pt hitch. Mine appear to be crimped in place at the factory. Is there a trick or are the replacements only for certain model links?
/ Replacing the ball in top/lower links #2
Its been along time for me but: I remember them being made so
they can only be installed one way to hold them in place or a set
screw is used.
If they (being the bearing races) are crimped in place
EEWWWW!!!!!!!!!, you may be in for some replacement upper
and lower links.
/ Replacing the ball in top/lower links #3
Most common are the weld on ends with the crimped in ball. Some-most JDs have ends where the ball gets turned 90* and will fall out of the ball socket. This is for the top link and the side link ends. I am not sure about the draft link ends. :ashamed:
/ Replacing the ball in top/lower links #4
Draft link ends are swaged in on mine, as is my factory top link. If it ever needs new ones, it'll be torch and welder time. No biggie.
So in theory I could grind the swage off one side, replace the ball, then lay some weld back on the outside to retain the ball?
/ Replacing the ball in top/lower links #6
Why?, Just cut the bad end off and weld on a replacement.
/ Replacing the ball in top/lower links #7
If you're able to do that without welding the ball in place, please put up a how to thread. The technique might come in handy.
/ Replacing the ball in top/lower links #8
If you had a ring of steel the right size, you could fillet weld that over the ball and not fuse it to the ball itself. The heat and contraction from doing so would likely shrink the eye down onto the ball and seize it - so there's no up side to the concept. Just replace the ends as needed.
/ Replacing the ball in top/lower links #9
In case someone isn't familiar with a repair end:
CountyLine Lift Arm Repair End, Category 1
Bruce
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
39' 9" 3-Bar Drag Tooth Harrow (A66285)
39' 9" 3-Bar Drag...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
