Dump Trailer with b3200?
/ Dump Trailer with b3200? #1
caloway
b3200hst
Was looking to see if anyone here has experience using dump trailers with CUTs. I'm picking up a 6x10 dump weighing in at 2500# and would like to pull it sometimes with the tractor rather than hauling the truck around to pick it up.
Loaded it would be over the max GVWR, but I'd be pulling on level ground for about 1000ft. Wouldn't exceed max drawbar, only max tow. I was thinking I could just drop the HST down and it would be fine.
Thoughts?
/ Dump Trailer with b3200? #2
That would be fine for me! Low range will spin the tires and still leave you safe for acceleration but if you are baking going down a hill I hope you start out in 4 wheel drive!
/ Dump Trailer with b3200? #3
Art- is "baking" going down a hill same as "cooking"? Sorry, couldn't resist.
/ Dump Trailer with b3200? #4
I used a 5ton dump behind my B3300su with loaded tires all the time. Never felt unstable or out of control.
/ Dump Trailer with b3200? #5
That's good to know. The Manual for my L3010 says 1100 lbs max draw bar and 3300 lbs max trailer. I always thought that was a little restrictive and it has actually stopped me from getting a trailer because keeping in those parameters would not get me what I need.
gg
/ Dump Trailer with b3200? #6
I know I've had in excess of 5ton behind my MX4800. I'm sure there are many on here who would say that was criminal but it has alway felt safe.
That's perfect. Did you ever have issues dumping it? I have loaded R3's, so the rear end is pretty heavy.
/ Dump Trailer with b3200? #8
I've pulled 3 tons of rock on a trailer behind my L3200, and it did fine. Just be careful on hills and use 4x4 when braking is critical.
/ Dump Trailer with b3200? #9
I have a 5X10 dump trailer and it has 20 inch high sides on it. I can fill it level full with sand and pull it fine with my 3301. It will push you if you try to stop fast. My ground is level also. On dumping I have no problems and I hve R4 tires loaded
/ Dump Trailer with b3200? #10
No. My hitch is now attached to a ballast box so that keeps things down. On my B3300su I just used a 3pth trailer mover like you get a TSC. That would occasionally flip the 3pth up towards the end of a dump (especially with something sticky like wet dirt). But by then there's not much weight in the trailer so it's not much of a jolt.
/ Dump Trailer with b3200? #11
Just load it right and watch the draw bar you can bind it, and for god sakes don't use the 3pt.
/ Dump Trailer with b3200? #12
Lol. I was waiting for that! 3pth works fine for me but make you own decision.
/ Dump Trailer with b3200? #13
That's exactly what I want to do. Pull the trailer to the quarry with the one ton and bring back a couple yards of rock. Transfer the trailer to the tractor and dump the rock on a woods road. My L3010 tractor has a geared transmission and weighs about 5000 with the loader and loaded tires. I don't know anything about trailers but it seems like 2.7 ton of rock plus the trailer might be a bit much ?? What I am reading here says it would be OK ??
EDIT: I am not trying to hijack your thread caloway - I think we have the same question. I apologize if I am out of place.
gg
/ Dump Trailer with b3200? #14
I am guessing you have never operated a farm tractor with a manure spreader on it and watched the drawbar spring up and down. LOL
/ Dump Trailer with b3200? #15
I one time hooked my dump trailer to the 3pt and was going down a hill while dumping, it came unhooked and set right down on it's tail gate. I tell you that no one wants to go thru that. Now it is always hooked to the draw bar and never dump going down a hill, or unlevel ground.
/ Dump Trailer with b3200? #16
I was always afraid of it coming unhooked and coming up in the back of the seat. Mine is good as far as jumong up. Last fall I found that I could load it with wood and raise the dump without it hooked to the tractor. It just sit right there, but sand may be a different story
/ Dump Trailer with b3200? #17
Just keep in mine the 3pt can float up.
/ Dump Trailer with b3200? #18
I am familiar with a B3200 as I put 1200 hours on one before trading it for an L model. I also had a 6x10 dump, but I confess i never pulled the trailer with the tractor. My dump trailer would lift the rear tires on my F150 to a point where I had very little traction. It would spin out if there was a heavy dew on the ground. So that is one aspect to be careful of when dumping a loaded trailer. I would put no more than 2 yards of rock in the trailer. I wound up bending the rear axle because I loaded it too heavy and did not have the trailer sitting level when loaded. I hope your trailer has the adjustable hitch which should be set so that the trailer tows level. At least that is what I think I did not do right when I bent the rear axle. Threw too much weight on the rear. I would only attempt what you want to do on level ground and in 4 wd constantly in low range.
/ Dump Trailer with b3200? #19
Leejohn makes two good points. When backing up it's possible to bind the drawbar and get yourself into a "jackknife" situation. When this happens, if you keep backing up your inside rear wheel will start lifting and you're on your way to rolling over. Don't ask how I know. As for the 3pt lifting, that can create a whole other set of complications. This happened to me with a load of wood, going uphill, the load shifted aft and the tail of the trailer dug in. The result was a loss of traction that took some futzing with to get the load back in front of the trailer axle. You can limit this tendency by securing the 3pt hitch with a chain. Just make sure you make a good, secure connection between the toplink and the drawbar:
/ Dump Trailer with b3200? #20
We have rebuilt many three point hitches over the years from when things went wrong! I'm glad you have had success with what you have been doing but normally what will happen is you will take out the hitch hydraulic assembly when it slams up and blows the lift cylinder out of the housing. There has been times we have seen it break out of the body but that is rare but they will bottom out and need the whole assembly replaced. I wish you luck!
UNUSED WOLVERINE TDB-11-66W 66" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2500 GALLON INDUSTRIAL TANK (A62130)
2500 GALLON...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
