Bent turnbuckle on my MX4800
/ Bent turnbuckle on my MX4800 #1
aarolar
Augusta Ga
Kubota MX4800
I have finally destroyed the cheesy turn buckles on my MX4800 and I want to upgrade to the telescopic end links and tube sway adjustment. Anyone know how much the kit should run through my dealer?
/ Bent turnbuckle on my MX4800 #2
I've the "cheesy turnbuckles" on my B7610 and bought the upgrade kit back in 2010 for about $250 from a 3rd party. Have not installed it yet because life got in the way.
/edit - try contacting Rosseel's in MI.
I emailed them recently regarding a 3pt hitch for my backhoe, their price beat my dealers even with shipping.
Looked it up:
Rosseel's Farm and Garden Supply, Inc.
50025 N. Gratiot, Chesterfield, MI 48051
Phone: 586-949-0822
Fax: 586-949-2872
URL: Home >> Rosseel's Farm & Garden Supply, Inc.
E-mail: dan.rosseel@gmail.com
Store Hours (EST):
8am - 5pm weekdays and 8am - 2pm Saturday
/ Bent turnbuckle on my MX4800 #4
/edit - try contacting Rosseel's in Minnesota.
Phone: 586-949-0822
Fax: 586-949-2872
Umm, MI or MN? I'd guess Michigan given the MI, zipcode, and area code.
/ Bent turnbuckle on my MX4800 #5
Yup, I wrote that before I looked it up, just remembered a cold Midwest state that started with M and didn't know if I still had the address :) .
/ Bent turnbuckle on my MX4800 #6
Ill try to find my invoice.
/ Bent turnbuckle on my MX4800 #7
$400 a year ago.
/ Bent turnbuckle on my MX4800 #9
Yup! :confused3:
Kicking myself for not upgrading at time of purchase
/ Bent turnbuckle on my MX4800 #11
Unless you can run all of your implements with a Quick Hitch, it's worth the money.
Yep we have that setup on our Ford 5030 so I am familiar with it and miss it big time I can't believe no one makes a weld on kit.
/ Bent turnbuckle on my MX4800 #13
Just FYI: your tractor is listed as a MX48pp. Might want to correct that in your profile.
I can't figure out how on tapa talk already tried
/ Bent turnbuckle on my MX4800 #15
Might be worthwhile to check with some tractor salvage yards. No matter what the condition of the parent tractor is, those telescopes should be A-OK. Other brands maybe can be made to work. Probably a bolt on I would think.
/ Bent turnbuckle on my MX4800 #16
I lost one of my turnbuckle 'barrels' and replaced with a complete new set (pair) found on EBay for less than the 'barrel' alone.
But then again I am in trouble as one of the threaded ends got stripped and is unusable as is.
While it will be inconvenient to use I'll simply weld the stripped end in place and probably do all my adjustments from the other side.
/ Bent turnbuckle on my MX4800 #17
Standard Cat I top link is $20 at Tractor Supply. Looks a bit different than Kubota but does the same job. Paint it gray if you need it to match the tractor.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
2013 Nissan Altima Sedan (A61569)
2013 Nissan Altima...
2014 John Deere 350G Excavator (A60352)
2014 John Deere...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
