Bent turnbuckle on my MX4800
   / Bent turnbuckle on my MX4800 #11
Unless you can run all of your implements with a Quick Hitch, it's worth the money.
Yep we have that setup on our Ford 5030 so I am familiar with it and miss it big time I can't believe no one makes a weld on kit.
   / Bent turnbuckle on my MX4800 #13
Just FYI: your tractor is listed as a MX48pp. Might want to correct that in your profile.
I can't figure out how on tapa talk already tried
   / Bent turnbuckle on my MX4800 #15
Might be worthwhile to check with some tractor salvage yards. No matter what the condition of the parent tractor is, those telescopes should be A-OK. Other brands maybe can be made to work. Probably a bolt on I would think.
   / Bent turnbuckle on my MX4800 #16
I lost one of my turnbuckle 'barrels' and replaced with a complete new set (pair) found on EBay for less than the 'barrel' alone.
But then again I am in trouble as one of the threaded ends got stripped and is unusable as is.
While it will be inconvenient to use I'll simply weld the stripped end in place and probably do all my adjustments from the other side.
   / Bent turnbuckle on my MX4800 #17
Standard Cat I top link is $20 at Tractor Supply. Looks a bit different than Kubota but does the same job. Paint it gray if you need it to match the tractor.
2000 Polaris Sportsman 50 (A50515)
2000 Polaris...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2005 Pierce Enforcer Special Operations Fire Truck (A50323)
2005 Pierce...
Ford Pickup (A50323)
John Deere X740 Mower (A50514)
John Deere X740...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
