sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,721
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Wondering what kind of set ups Tbners have come up with for cutting circles on outside projects- where the hole needs to be cut (on the job).
Wanted to change my trailers tie down brackets on my fifth wheel. The tie downs I have have a hook and there was no good way to hook them on the tie down points on my trailer.
Last time out one actually popped off after hitting a good whoopdee doo in the road
I tried boring a hole with my stepped drill, but it was taking forever and gave up. Next tried the plasma free hand- Well that ain't going to do.
finally found an old magnet steel support from a blown subwoofer and used vice grips to hold it to the tie down mount and using the (wire) plasma cutter tip guide was able to cut all 17 holes. finished last night :cool2: Seen here after returning from the 1 st trip and test.
just made it into our drive today with some Alfalfa and wife noticed the tire was almost flat..:thumbdown:
The speaker (guide) worked to plasma cut the holes for me, but will only do one hole size ...
What do you guys use when doing outside (the garage/shop) circle cuts with plasma???
It would be nice- if someone has made/ bought? an adjustable version..??..
just made it into our drive today with some Alfalfa and wife noticed the tire was almost flat..:thumbdown:The speaker (guide) worked to plasma cut the holes for me, but will only do one hole size ...
