Heavy discs on Ford 2000?
/ Heavy discs on Ford 2000? #1
Mearntain
Gates, NC
Ford 2000
I'm in desperate need of getting some discs, and can't seem to find a set of used ones in good enough shape. I was considering buying a set of County line 7' heavy discs. I've got a 3 cylinder gas Ford 2000. Will my tractors hydraulics be able to lift these discs with no issue? Thanks
/ Heavy discs on Ford 2000? #2
very likely no.
6-6.5' are about as big as your 3pt will run. 7+ and you want a disc with travel wheels.
most of the farm dealers ( tsc, rural king ) have 6' disc.. heavy box, or cheap angle frames.
just load up with some ballast.
The sticker/tag on the discs say 6.5 ft but it rings up as 7 ft and the website says 7 ft. Not sure what the exact measurement of it is though.
This is it right here :
CountyLine Heavy-Duty Disc, 7 ft. - For Life Out Here
You don't think it could handle that? I thought the TSC ones weren't really too heavy.
I was just looking at the site, and these discs weigh around 860 lbs. The 6.5 foot one they have weighs 553 or so. Which do you think would work best for what I've got?
/ Heavy discs on Ford 2000? #5
if i am not mistaken the 1968 and up 2000-3000s can lift 1700+lbs. on the 3 point.
Mine is a 1970. When relooking at the discs again on their site, it seems as if the 7' really only can cut 6.5', and seems that the 6.5' really cuts 6'.
Is there anywhere you know that I can look to verify the lifting load for my tractor? I've got em holding the larger one for me now but would need to call asap if I need them to change it, and was going to pick it up tomorrow.
/ Heavy discs on Ford 2000? #7
I have a 7' that ran fine behind my old 820 JD 3 cyl, no problems lifting it either.
Ronnie
/ Heavy discs on Ford 2000? #8
Mearntain, we used a heavy 7' (nominal) disk behind our ford 3000 diesels for years. I is is all you want to pick up with the 3 point hitch. You may need weights on the front end because it will be light. W Jones.
/ Heavy discs on Ford 2000? #9
Weight of the Disc Harrow is the main factor in how it cuts, until its sinks to pan hubs. To a lesser extent, how the gang axles are set affects how it will cut. The third factor is pan spacing. Seven inch pan spacing provides much more float than nine inch pan spacing. More float, less penetration.
Disc Harrows, tilling deeply, resist with considerable draft force. So your tractor tire types, whether the rears are filled and whether or not you have 4-WD make a great deal of difference in what your tractor can successfully pull. In order to get good soil mixing you need to pull at a brisk walking pace, minimum. Soil moisture is also important.
The best way to discuss Disc Harrow for compact tractors begins with pan diameter, pan spacing, total weight, then width. You need at least forty pounds bearing on each pan to cut well with 9" spacing. Fifty pounds is better. Disc with seven inch spacing are pretty much smoothing, rather than cutting Disc Harrows. If your primary use will be smoothing plow furrows, seven inch spacing will leave a smoother bed than nine inch spacing.
Disc Harrow are measured for width with the gang angles flat, though the gangs will not cut set thus. As the gang angles are adjusted more aggressive they assume a > shape, therefor the width measured across decreases. So there is no "one" width measurement. Operating width will always be less than measured "flat" width.
A lot of what has been posted so far in this thread is just blah, blah, blah. Incomplete tractor information, incomplete Disc Harrow information.
/ Heavy discs on Ford 2000? #10
that's a very optimistic #, and IF it is in any way correct, it is measured right at the upper lift arms.. not post balls, where the weight is.
What some people fail to understand is that if you have an implement that is sticking out 4-5' from the back of the tractors lift arms, that felt weight out on that lever is much different than having weight right at the lift arm balls.
To the OP. if the lift on your tractor is in good condition, and you ballast the heck out of the front, you should be able to pick up the 800# set.
/ Heavy discs on Ford 2000? #11
you could always trailer your tractor up there and hitch up to it an pull the lever and see what happens. ;)
Soundguy, would you recommend going with the lighter weight medium duty one? I'd prefer not have something that the tractor is gonna struggle with. I'm going to be moldboard plowing prior to discing, so I won't be cutting virgin ground with the discs. The only thing I didn't like about the medium duty one is that the rear arms seem really weak, which is why I was thinking the Heavy one might be a better route. Tractor width is 72 inches I believe.
I don't have an equipment trailer currently so I wouldn't be able to do that unfortunately.
/ Heavy discs on Ford 2000? #13
Rather than by a small disc I would get a 6' tiller.
Update on tractor width. I was looking at tractor data and it says my wheel base is 75.8 inches, so close to 6.5 ft. It seems like that 6.5 disc won't cover up all my tire tracks. Same with the 6' tiller.
/ Heavy discs on Ford 2000? #15
Wheelbase is front to rear axle to axle not side to side.....
/ Heavy discs on Ford 2000? #16
tractordata.com: TractorData.com Ford 2 tractor dimensions information
Above data is for the three cylinder, gas tractor.
Width of 63.375" is with R1/ag tires supplied on the tractor when new.
You may not have ag tires. Take a tape and measure your outside to outside width.
/ Heavy discs on Ford 2000? #17
I have misplaced a 2000-3000 brochure, but am pretty sure it stated 1700lbs. at the lift balls.
most complaints about lifting problems with 2000-3000 tractors without loaders is not the lifting capability of the 3 point but the front tires lifting, even with calcium in the front tires.
Even though the 2000's hydraulic pump has less gpm than the 3000, i believe the actual lift rating is the same.
My 3000 will lift the heaviest 3 point implements i have ancient Ford HD 6 foot rotary cutter ( MUCH heavier than my Woods Brush Bull ) my 76 inch Gannon box blade (1000 lbs.) and my 85 inch tiller Has to be (1200-1300 lbs.)
Have read other posts where 2000's have been used to move round bales on the 3 point and the front end lift was a problem -not the 3 points lift capability.
All that said- you may be happier with the smaller of the 2 discs if you get into some hard to disc ground
/ Heavy discs on Ford 2000? #18
Ford tractors usually have strong 3PH hydraulics. I don't think you would have any issue lifting a 7 foot (860 #) disc with proper front weights but pulling it is a whole other question. I have a heavy duty 8 foot disc and it taxes my 70 HP LS's traction when it is cutting to the axles and in full set.
If you plan to use it just to bust up the turf behind a bottom plow where you will carry a lot of the disk weight with the tractor, a 7 foot might work for you. It would certainly still be beneficial if you decide to upgrade to a larger tractor later.
/ Heavy discs on Ford 2000? #19
if you get the heavy one.. load the tires... get front ballast.
I agree. 800# should lift if the lift is in decent repair.
/ Heavy discs on Ford 2000? #20
It should be possible to adjust the track width:down to about 63 inches on the rear.
2000 tread width.jpg it may pay to just try it as is though, you may be surprised how good it comes out. Interestingly you can set the track width to almost match the wheelbase.
