Tree puller for little tractors
/ Tree puller for little tractors #1
bcp
Super Star Member
SW WA
Kubota BX2360
Now, add a hydraulic clamp for trees without forks.
Bruce
/ Tree puller for little tractors #2
Now we're talking!!!! Actually, if the V is shaped and sharpened right it will dig into the trunk. Only thing I'd question is that his fruit trees don't appear to root very well.
Very cool though. Makes me want to copy it. Maybe a next Winter project!!!! :)
/ Tree puller for little tractors #3
No ROPS on that tractor.
/ Tree puller for little tractors #5
I'm thinking a puller with a sliding mechanism that has teeth for grip and as you approach the trunk there's a V shaped collar that tightens as you lift like a slip knot sort of.
That way you'd have grip that only gets stronger as you lift but when you lower it opens up.
/ Tree puller for little tractors #7
And that reminds me of a large version of a broom holder.
Bruce
/ Tree puller for little tractors #11
That back piece could be a ssqa and with two of the curved tooth arms facing each other it would make an awesome tree puller. Just backing up would allow you to reposition and you could put the tree down to release them.
Could be made for 3pt as well.
/ Tree puller for little tractors #12
I had thought of something like that for my little sub compact. 6" cylinder with a place to hook a chain mounted on the 3 point. Set it on the ground and hook up the chain pull the leaver and POP. Hopefully the tree not the chain. I only have a few scattered trees so the chain would work well and it would have more power closer to the cylinder. Ed
/ Tree puller for little tractors #15
What I like is all the tractor is providing is hydraulic power and the ability to carry it. No stress on the tractor chassis or FEL.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
Lifts (A61567)
Lifts (A61567)
2013 JOHN DEERE S550 GRAIN COMBINE (A64277)
2013 JOHN DEERE...
