New LS owner with a few questions: XR4046
   / New LS owner with a few questions: XR4046
Thanks! I can tell from those pictures the size. I was also looking and see you have the HD Titan pallet forks. How do you like them? What about the fit and quality?
   / New LS owner with a few questions: XR4046 #13
I do have the Titan 48" x 4000 lb. pallet forks. What you see in the picture is the Titan 60" fork extenders. They are very handy for really
large items. They just slide over the forks and lock in behind forks so very stable.
   / New LS owner with a few questions: XR4046 #14
Before modifying my grill guard, I took it to Sherwin Williams and had them color scan it.
Ended up with a great match to the LS Blue.
This paint has proved to be very durable too.
   / New LS owner with a few questions: XR4046 #16
I copied Rigustafson's brush guard. Thanks for the idea. I used items I had on hand and think it turned out pretty good.brushguard.jpg
   / New LS owner with a few questions: XR4046 #18
   / New LS owner with a few questions: XR4046 #19
I used pad eye and Clevis so I need only one chain on front and one on rear. Chains slides thru the Clevis when tightening.
   / New LS owner with a few questions: XR4046 #20
I thought of that (one chain front and one back) but decided to go with 4 separate chains. With the two chain approach if one chain or binder breaks that leaves nothing to hold the tractor because the second chain would go slack.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
19008 (A56859)
19008 (A56859)
iDrive TDS-2010H...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
