XR3230 Remote Control Valve problem
/ XR3230 Remote Control Valve problem #1
BrittCook
Kenai, Alaska
LS/XR3037HC
LSTractor XR3032HC
Having problems with my G827S0102 Remote control valve. Tractor is almost new & Detent Control is very difficult to get in and out of detent. Tractor is under warranty by I am quite a distance from my distributor. Anyone with similar problem or solution?
/ XR3230 Remote Control Valve problem #2
Cycle it in and out of detent many times to see it it will loosen up. I know my loader was tight from the start but it has now lost that tightness and operates just fine.
I have not looked at the control function before but I would think it could be adjusted.
/ XR3230 Remote Control Valve problem #3
The detent on my XR4046HC was really still at first but, after a lot of use, its fine. As stated above just cycle it a bunch of times.
/ XR3230 Remote Control Valve problem #4
I think the OP is talking about his remote, that has detent.
Think you are talking about the "float" function on your FEL. My "float" is still hard to pull it back out of float. Probably just need to exercise it a bit. Mine seems to be getting better.
The float on my New Holland TL100A with Bush Hog 5045 was stiff to operate at first but, eventually smoothed out. Goes in and out nicely now.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
