Dry cut chop saw
/ Dry cut chop saw #21
It was mild steel. Maybe I put to much pressure on the handle. I don't know. All I know the motor smoked and my new saw on it's way. It it close to my Milwaukee 8" metal saw I will be happy.
/ Dry cut chop saw #22
I bought an evolution dry cut saw and it was a complete piece of crap. Table was cast so badly it wasn't even close to flat or square to the blade. Looked at it for about 1 minute and put it back in the box. I'd stick to Dewalt, Milwaukee (discontinued) or what I ended up with, the Makita.
/ Dry cut chop saw #24
Milwaukee's base was cast aluminum and a sight to behold, but the handle ergonomics were bad. I got my Dewalt with the intention of mounting it to a stand and eliminating it's crappy stamped base completely, but I ran out of room. :laughing:
Dollar for dollar, my 4x6 bandsaw (happens to be a Jet - but they're all virtually identical) remains the king of quality for precision cutting and cost per cut on consumables. The only problem with it is how slow it is. If you're going to post-process the cut edge (say; mill it square), then an abrasive chop saw is fast and cheap. But if you're going to weld it directly off the saw, the bandsaw can be set up to make a near perfect end to go directly to the weldment. Grind off your tab burr and you're ready for fit-up.
My bandsaw blades (bi-metal, US made) seem to do well against things like 304 SS, chromed hydraulic shafts and hydraulic cylinder bodies, etc. Only downside is speed - which can be made up by the fact you're not trying to true it after the cut in some applications. Those tree plug planting tools I posted have a weldment on one end of 2 out of 3 pieces, and are fishmouthed in a mill before fitting on 2 mating surfaces. The ends of the handles are clean after deburring with a chamfer cutter and flap wheel, so the textured smooth face left by the dry cut is perfectly acceptable even if not precisely all that square to the axis of the tube.
/ Dry cut chop saw #25
I have a 4x6 bandsaw Jet also.
I have a 1" Starrett band saw. It cut great. But if you need to cut something out side you shop. A chop saw the tool.
/ Dry cut chop saw
got it today and cut a piece of angle. It cuts easier and is not as loud as an abrasive saw. I touched the cut edge right after the blade cleared, it was barely warm. It's perfect for occasional use. I was either going to buy this one or the harbor freight abrasive saw for once/twice a year mig welder projects.
/ Dry cut chop saw #27
I have the Northern version dry cut saw. I ruined the blade cutting 2 3/8 and 2 7/8 pipe for my pens. I quickly found out that when cutting pipe you have to rotate the pipe after about 3/4 of the cut. Trying to cut the bottom of the pipe without rotating it will wear out the blade very quickly. I can now cut pipe with torch, dry cut saw, abrasive saw or band saw. What I choose to use depends on what I am cutting, how clean a cut I need, how fast I want it cut and what is closer :) In general, I save the dry cut for the precision cuts in mild steel.
/ Dry cut chop saw #28
Morning Wood, which Evolution did you send back? They make an inexpensive one with stamped steel base and no quick release on the vise, and a higher priced one with cast base and quick release vise. Curious which one you sent back... Steve
/ Dry cut chop saw #29
Is the MK Morse CSM14MB USA made?:dance1:
/ Dry cut chop saw #30
Cast base. POS.
/ Dry cut chop saw #32
Morning wood - good to know, thanks... Steve
/ Dry cut chop saw #33
I'm not herring many positive things about these so called outstanding dry cut metal chop saws, I was going to put it on my wish list, don't want it my, wish I never bought it list.
/ Dry cut chop saw #34
This is an interesting thread. All my "cutting to length" is done with my 6"x9" horizontal bandsaw or abrasive chop saw.
I would NEVER part with my 14" Makita abrasive. It's over 35 years old and hasn't missed a beat. QCD. **quick cheap & dirty***.
Having said that I'd love to at least TRY a dry cut saw one. day. Perhaps I don't know what I'm missing.....
Terry
/ Dry cut chop saw #35
HF was having a "closeout" sale about 6 years ago, and I bought a 14" carbide tipped "cold cut" blade for $40 - I knew it wasn't rated for the speed my Ryobi abrasive chop saw runs at, but decided to put on welding leathers, face shield, lean 'way off to the side of the "trajectory", and see what happened -
What happened, was about 20 cuts on .120 wall 2" square tube that looked laser cut - then, by about cut # 25, I could hardly put enough pressure on the handle to get it to cut.
Just gut feel, I blame about half of the short life on HF "quality", and the other half on running approximately 2.7 TIMES the speed those blades are rated for -
Even that "failed" experiment showed me these things have promise, but I'm like others have mentioned, getting the WRONG one isn't a very cheap mistake - plus, similar to Terry I have a larger Jet bandsaw (7x12) and two of the HF 4x6 saws, zip disks, abrasive chop saw, plasma, and O/A torches if things get thicker than 1", so I'm not in a rush to make a bad choice here.
Still looking... Steve
/ Dry cut chop saw #36
Terry
Yep, you don't know what you are missing :D.
I use mine for precision cuts, it is very high quality and well built.
/ Dry cut chop saw #37
No, you've never used a true Cold Saw - the kind with coolant bath. ;) YOU don't know what you're missing. Those run slower yet, and actually have blade life to offset the price of admission. HSS blades that you can resharpen time and again, and never blow out a carbide tip from too thin of steel. Those blades are a few hundred dollars, the saws are a couple grand. I think of it like growing up and being tainted. Remember when Mc Donalds burgers were the best and their slop of a milkshake was enough to make it a Kings feast? Then as you grew older and your exposure to finer foods grew, that happy meal became anything but... When you use a plasma it's better than a torch, but if you use a laser that plasma looks like a back-yard hack's worst day.
Dry saws have their place. They're not that high up on the totem pole in the grand scheme.
/ Dry cut chop saw #38
I can't comment on the dry cut saws (never used one). As far as the true cold cut saw with coolant goes... Top notch! I use one at work and they are awesome! We cut everything from very thin wall tube up to 2x2 solid stock and it just keeps going!
/ Dry cut chop saw #39
Do you mean a band saw with coolant?
2016 Deere 180G (A60462)
2016 Deere 180G...
1975 Bomag MPH1 Reclaimer Mixer / Soil Stabilizer (A61572)
1975 Bomag MPH1...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
