Detent valve sticking
/ Detent valve sticking #1
Stx22
NH
Kioti CK 35 HST
I am a newbie here, but I can't seem to find an answer on here, so I'll throw it out there.
I just installed a rear remote on my Kioti CK35 HST (none to 1). After installation, everything checked out, no leaks, etc.. but the linkage/lever is very difficult to disengage. I have not hooked it up to an implement yet, but it seems that the valve should be a lot easier to engage/disengage. It appears as though the ball valve for the linkage may not be seated properly (or lubricated properly). Suggestions welcomed.
/ Detent valve sticking #2
My brother has the DK35 and I went into it and loosen it up. I just can't remember how I done it. It did help some , but he's been thinking about removing the detent all together.
/ Detent valve sticking #3
In the 11 y since I installed mine, it has sometimes been hard to disengage. Sometimes not. At one point,
I considered opening it up and shortening the spring in the detent mech. I guess I will wait until it gets worse.
I use mine all the time to power the hoe, so it gets plenty of OFF-ON action.
If you decide to open it up and do the mod, I hope you post.
