I think I have my first issue.....CK2610
   / I think I have my first issue.....CK2610 #21
When cylinder rods are fully extended, like when the bucket is fully curled and angled toward the back of the tractor, the cylinder rods are at their most vulnerable position.
459506d1420664710t-i-think-i-have-my-kgrhqj-jqe1j6qc9n4bny9ojej-g-_35-jpg
UN-believable! :eek:
I was back dragging yesterday and ALL I could think about was this picture!
Just made me aware of how I was putting pressure on the FEL and it's components.
   / I think I have my first issue.....CK2610 #24
As long as you don't start trying to dig out, roots, stumps or rocks back bladeing with a full curl you'll be fine. I only mentioned in an earlier post so others might avoid what I did with my last tractor 3 times. I was able with my 20 ton press to straighten the rams each time but you have to pull them apart to do it. Also they can only have a slight bend not like the posted pic.
   / I think I have my first issue.....CK2610 #25
[snip]I was able with my 20 ton press to straighten the rams each time but you have to pull them apart to do it. Also they can only have a slight bend not like the posted pic.
Well done, that's impressive! :thumbsup: Were you able to get them straight enough to have no leakage past the gland seals on the rod ends of the cylinders?
   / I think I have my first issue.....CK2610 #26
Yes Threepoint over 30 years ago I bent a dipper ram on a case backhoe and had a machine shop straighten it for me and watched closely how they did it so yrs. later was able to do my own. Seals are very for giving if the surface is smooth and your within ?( maybe 4-5-10 thou.I don't really know) . But none ever leaked because of being straightened.
   / I think I have my first issue.....CK2610 #27
I've happily never bent a ram but am I right in thinking the design Kioti uses with their loaders (the ram doesn't push on the bucket itself) makes it a bit less likely to getting bent?
E.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
UNUSED FUTURE SB05 MINI HYD BREAKER (A57193)
UNUSED FUTURE SB05...
1991 FREUHAUF 40FT BELLY DUMP TRAILER (A57880)
1991 FREUHAUF 40FT...
