MF283
I'd say if he had messed up, we wouldn't be seeing a video, luck, skill wins a lot, just looking at the surrounding, i'd say they didn't have the $$ to pay for a high price outfit.
Ronnie
Ronnie
I did google it and I wouldn't make the back cut the way they did in all of the unsafe videos., they were much too sharp a slant and right to the point of the notch. The cut should end up above the point of the notch so that you still have a hinge.... and yes, so I don't have to use wedges. No need on a smallish tree like that. If it were a windy day or even a slight risk of that tree going the wrong way, we would climb it and put a long bull rope in the top and pull it along with the notch.... not trusting a wedge to send it the right way... not around houses... in the woods maybe ok. I agree he looked like he had droppod a lot of trees in the woods.
I would have made the cut on the back side, away from the notch, above the notch about 2 inches and slanting down toward the notch. That way I wouldn't have to use wedges. I think he was lucky, thats all. I have dropped and watched my brother drop 100's of trees in his tree service. Who has their saw on the side the tree is going to fall? He is just lucky it didn't pinch the saw.
https://www.youtube.com/watch?v=Dk0JSn5WDTE
The slanting back-cut thing is not a good method. It has no benefit, it prevents you from using wedges, and makes it unnecessarily difficult to line up the back cut with your hinge. If you're felling trees, there's no reason not to have wedges on your belt. They are great tools. What exactly do you think making the back cut on a slant achieves?? Google it, it's been thoroughly explained why it's not safe.
Regarding this video, I agree with the poster who said that the guy is a professional felling this tree at his home or the home of a friend. No way Joe Schmoe takes this one on and nails it like that.
I agree, no benefit to a sloped back cut. IT does nothing to prevent saw pinch. The notch cut and natural lean of the tree determine if a saw is gonna pinch. Wedges are assurance and can guide a tree to a precise location if you are good. Or can overcome a little natural lean and fell a tree in a direction other than it would normally want to go.
Have felled hundreds of trees myself. And the only thing a sloped back cut does is leave an ugly stump, and an ugly log
When I first started I had an old logger tell me not to throw a tree where it will go easy. Always throw it to one side if you have room, that way when you need to you know what you are doing and what you can't do. Ed
Ronnie
Agree. Sloped back cuts are intuitively silly.I agree, no benefit to a sloped back cut. IT does nothing to prevent saw pinch. The notch cut and natural lean of the tree determine if a saw is gonna pinch. Wedges are assurance and can guide a tree to a precise location if you are good. Or can overcome a little natural lean and fell a tree in a direction other than it would normally want to go.
The hinge is what guides a tree to a precise location. Plastic felling wedges behind the saw can overcome slight balance problems and get the tree falling before you cut the hinge too thin. The hinge must remain intact for about 45 degrees to be fully effective. Minor wind will have no effect while the hinge lasts.
How do you keep the hinge intact for 45 degrees? Isn't brittleness of the fibers more related to the type of tree, season, etc..? Can relative height of the backcut to the open side wedge height effect how long hinge holds?
On another subject: Look at the last 2 seconds of vid where it shows the stump on the open face side. We never see what kind of wedge he cut on the trunk that falls, but judging from the uneven wedge cut on the stump, it seems lucky the trunk didn't kick left on it's way down.
It also clues on that the faller was a rank amatuer. I heard of a guy got an 'in' to cut black locust (rareity in these parts) and took out a power pole. Ihad be sort chasing that site myself so went out to look. Stump clearly showed that he had tried to use the sloping cut plus wedge to try to force the tree opposite the lean. I had eyeballed that tree myself and knew it leaned wrong. $10,000 later he was a wiser person. I heard that his home insurance paid.
Harry K
