Heavy Trailer: how would you make a 10/14K dual purpose trailer?
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #31
My buddy up there said 52F yesterday. I haven't been up North since last weekend. I live in suburbia until I can get the new house built.
I'm leaning towards a PJ or Johnson trailer right now. Looking at MN laws about home builts, I get to pay the state 6.5% but I can't write off my labor without risking an audit.
There's a couple tri-axle's down in Illinois that are cheap ($1200) and possibly built on trailer house frames I'm trying to get a trucker buddy to check on when he's in the area, but those look a lot heavier than I need and keeping it lean is a priority due to my little tow vehicle.
I do not tow often, but have a 7400 lb. load on a 3240 lb. trailer for a gross of approximately 10,640 lb. (trailer GVW is 14,000)
I tow with a 1997 K2500 Suburban 4x4 with 454 V-8. (8650 GVW)
I use an equalizer weight distribution hitch, and am about to add an Airlift LoadLifter 5000 air spring kit.
I don't tow over very much hilly terrain, so the vehicle is quite capable for the pull.
My concern is about braking! I do highway driving, I drive very defensively, and set my electric brakes to begin very early in the braking process.
It is not optimal, but I tow on usually dry roads, and a total of only 600 miles per year.
I would love to have a dually!
This is my serious towing rig.
The 2500HD will be my daily driver.
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #33
Jim,
What kind of package do you have for towing on the C65?
Most of my towing is done with an F550 4x4 service truck with a Class 5 hitch.
I don't have anything on it just yet. I need to shorten the chassis and get the dump box I have lined up put on it, then I'll figure something out for the rear end for a hitch mount.
It's hydraulic brakes - drum front and rear.
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #35
Jim,
That is quite a service truck... almost like something a Fire Department would have.
My c65 used to be a tanker truck for a FD. My hopefully soon to be 2500HD is also a former fire truck - but it's just a reg cab long box.
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #37
Works out pretty well, built the service body in 2002 for an F350. In 2005 when buying the 110tlb I went ahead and upgraded to the F550 with 33,000lb. towing capacity.
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #38
That looks like quite a rolling tool box! (and build) Gotta weigh 7-8 ton with those drawers full of tools.
I think we deserve a few close up pics.:D
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #39
If you think that truck is loaded then look at my main plumbing truck.
/ Heavy Trailer: how would you make a 10/14K dual purpose trailer? #40
Ok, 8-9 ton:laughing:
Are those drawer cabinets intended for (outside) truck use? I've stuck "tool box" drawer cabinets in a utility body compartment before and they could not stand up over time to the added (road shock) load.
You must have a small fortune in all of them! Well thought out work truck:thumbsup:
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
207275 (A52708)
207275 (A52708)
208320 (A58375)
208320 (A58375)
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
