Diesel Generator
/ Diesel Generator #81
Out of curiosity I looked at PDG's website -- they took generator product images from Central Maine Diesel (or GPP, who makes the gens for CMD) and photoshopped them!
pdgenerators
Isuzu 12 kW Diesel Generator
Lets hope they build a better generator than they do website work!
/ Diesel Generator #82
im a generac installer and service tech. I wouldnt touch a generator placed indoors UNLESS IT WAS UL RATED for indoor use, and those are mucho $$$$.
Personally, i dont install diesel units for one reason..i get messed with by EPA unless i create a diesel containment zone under unit. To do this to there specs is crazy expensive. If someone contacts me requesting diesel i dont bother with bid. I tell them why and let them contact a commercial installer.
As far as size goes, it depends on actual load against panel. Ive been able to get alot of heavy electrical dependant homes to work on a 22 kw air cooled unit using Generacs wireless load shed modules.
These modules allow the heavier duty loads to cycle on 15 seconds apart to spread out the start loads. They will also automatically shed them if the gen gets below 50 HZ. You can also set them to never run the perticular item if the generator is running. This feature is great for shutting down redundant water heaters or supplimental electric heat strips.
Ive been able to operate a large house with 400 amp service on a 96 amp generator without any issues.
But i do run into the occasionsl client that wants everything.... Including heated gutters, heated driveway and heated towel bars to run. For them, i use the 48KW QUIETSOURCE. If they have the money, ill supply it.
Then theres one guy with a 130Kw unit with 3 x 200 amp transfer switches.i was told that during the last power outage that lasted him 7 days, he was having his propane tanks filled every day. That unit sucks down between 11 and 22 GPH Depending on workload. Yeiks.
can you link to the load shedding module?
/ Diesel Generator
pdgenerators
I don't think that is actually them their company is PDG Generators (This is the manufacturer of the alternator only), the company that actually sells the completed generator units is Power House Generators they don't actually have a website and use Facebook and eBay as there sales source as they are a manufacturer. If you look at eBay and search Isuzu generators you should be able to find them and their specs.
/ Diesel Generator #84
PDG = Powerhouse Diesel Generators
The website, eBay, and Facebook page are all using the same "PDG" logo, so I assume they are all one in the same.
/ Diesel Generator #85
PDG does look to be photoshopped on the same image.
/ Diesel Generator
Fortunately, either way the engine is covered by Isuzu directly and they would be servicing the alternator head only. I did see the pictures on eBay and the only picture I found were of the actual units themselves. I am not as much concerned with their website as their service. If I can call and you pick up on the second ring I am happy, If the first person I talk to is knowledgeable about what I am inquiring and I don't have to be transferred from one person to the next I am even happier. All sales are an unknown until you make the purchase, and everyone thinks they made a good purchase until a defect presents itself. I looked at countless reviews for all companies and of course you always find complaints but I must mitigate risk with cost, and as it presents itself currently I think that they will provide the best price/package compared to risk. I spoke to the manager for about 35 min. and he answered every question I had. I was happy that they were close and that they have service providers in Florida, they would even do the install if needed. So at the end of the day I am happy with my decision, until of course when I have to come back and write about what ever failure has occurred.
/ Diesel Generator #87
Maybe it's an isuzu stock picture that anyone can use?
/ Diesel Generator #88
I don't think it's a big deal either way, but that's definitely not an Isuzu stock photo -- they colored out the stickers, Meccealte (gen head) logo, and covered the control head and all that stuff is unique to the GPP-built generators that Central Maine sells.
The reason I picked up on this right away is because the PDG picture looked an awful lot like the GPP unit I bought from Central Maine. Made me wonder if PDG was also reselling GPP units. When I looked closer, I noticed the Photoshop work.
/ Diesel Generator #90
Not much to go wrong with the alternator end. bearings, brushes and voltage regulators are as generic as socks.
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
250 GALLON FUEL TANK W/HAND PUMP (A62131)
250 GALLON FUEL...
378908 (A61166)
378908 (A61166)
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
