You need balast or you will trash your front axle!!!! really?
/ You need balast or you will trash your front axle!!!! really? #1
gladehound
PA
Kioti DS4510HS, Exmark Laser Z, Kioti LB1914
"You need rear ballast or you will trash your front axle"
I just read this in another thread and have often read similar things in others. It makes sense. After all, adding weight behind the rear axle removes weight from the front axle. I've always just accepted this statement... until now.
The reason I began doubting the validity of this is because the amount of rear ballast most people use is not enough to change the weight on the front axle substantially when a heavy load is lifted. I struggle to believe that a 10% difference in weight on the front axle is going to trash it.
If you don't get what I'm saying, let me give an example:
My tractor weighs 6500 pounds with filled rears and FEL and probably has 3,000 pounds on the front axle. If I pick something up with the FEL that is 2000 pounds and it is as far in front of my front axle as my wheel base is long, it adds 4,000 pounds to my front axle for a total of 7,000 pounds on the front axle. Now, if I had a 1,000 pound ballast box on my 3pt hitch, it would be about 1/2 a wheel base behind my rear axle. As such it would remove 500 pounds from the front axle and I would then have 6500 pounds on my front axle. Even a 2,000 pound weight box would only lighten the front by 1,000 pounds. So 6,000 pounds on the front instead of 7,000 pounds.
Even the 2,000 pound weight box doesn't make a big difference in the amount of weight on the front axle. Given this, I'm beginning to doubt the claim that you will trash your front axle without a counter weight.
Interested in Thoughts and or experience with what front axles have survived or not survived. My guess is that some tractors have over built front axles and it makes little difference while other s have under built front axles that will have problems regardless of what you do. Any experiences?
/ You need balast or you will trash your front axle!!!! really? #2
Rear ballast does take some load off the front. More importantly it helps with steering and handling. It keeps my rear tires on the ground when I have a full load. Also, reduces tipping when driving with a load. Improves traction when digging or climbing hills.
/ You need balast or you will trash your front axle!!!! really? #3
All I can say is that, in wet weather, if I have a bale on the front forks I like to have a bale on the double spears at the back to improve traction.
Don't get me wrong, I like lots of weight on the rear. I have 1000 pounds of fill in the rears, a 200 pound brush cage and 400 pounds of iron ~18" behind the rear axle. Factor in the 100 pounds I transfer from the front and I'm running 1,700 extra pounds on the rear and the tractor is very stable. If I need more weight I add additional weight to the 3pt hitch in the form of an implement or weights. My tires are also set reasonably wide etc. I like stability. But all of that is irrelevant to the question at hand - what's the real world impact on the front axle of not having a 3pt counter weight on when doing loader work.
Here's my every day set up. I like it because 1,700 pounds is enough to keep the rear planted and because it is right over or very close to the rear axle it keeps my front nice and heavy for digging in dirt and steering in snow. Plus it doesn't stick out at all so no maneuverability issues like you can have with a 3pt counter weight.
/ You need balast or you will trash your front axle!!!! really? #5
I've never understood this logic either. When you run ballast you increase the lifting capacity of the loader and in turn increase the stress on the front axle. Now if you do a front wheelie and the entire machines weight is transferred to the front... Obviously a different story.
/ You need balast or you will trash your front axle!!!! really? #6
I think you can actually apply more weight to the front axel with proper ballast. Try lifting a heavy load without ballast and the tractor simply tips over. Proper ballast allows you to lift the full capacity of the loader.
shortly after I bought my current property I bought a 20hp Kioti LB1914. I didn't know the property and was trucking through 2 ft of grass with a load of gravel when suddenly the front dropped into a ditch and the rear came off the ground. At one point didn't know if I would go full over the front till the bucket touched down or if it would go back onto the rear wheels. It did land back on the rears. I had filled rears and a back blade on.
The full 4600 pounds (tractor, loader, fill, back blade, me, load of gravel) was not only balance on the front axle, but that axle was slammed into a ditch hard enough to put the tractor in that seesaw position.
I thought for sure I broke the front axle. I didn't. Ran the tractor another 9 years before selling it and never had an issue. Front axle was stronger than I thought it was.
/ You need balast or you will trash your front axle!!!! really? #8
So you're guessing, and basing a theory on it? How about actual numbers, because the statement above isn't how the physics work out.
This thread had a nice spreadsheet on the topic....
http://www.tractorbynet.com/forums/...ng-ballast-hitch-post2977896.html#post2977896
Another with specific examples showing how weight was removed from the front axle by adding 3pt weight.
http://www.tractorbynet.com/forums/...-distribution-free-post973991.html#post973991
/ You need balast or you will trash your front axle!!!! really? #9
That simply isn't how the physics work. The rear axle is the center of rotation. If you were to put a 1,000lb ballast box on the 3pt hitch, it's probably somewhere around 36" behind the rear axle. You now have 3,000lb/ft of torque raising the front axle.
Not true because the front axle is some distance in front of the rear axle. Pretending that the rear axle is a pivot point and the rest of the tractor didn't exist there would be 3000 pounds of toque applied to it, but not nearly that much applied to the front axle. Most cuts have less than 3,000 pounds on the front axle, but yet can lift 1000 pounds or more on the 3 point hitch without lifting the front.
/ You need balast or you will trash your front axle!!!! really? #10
I edited my comment for clarity, but the rear axle is still the pivot point, and the amount of torque applied is the same. No, it wouldn't take 3,000lbs off the front axle, but I didn't claim it would.
/ You need balast or you will trash your front axle!!!! really? #11
You said you now have 3,000 pounds of toque raising the front axle. Also it is pretty unlikely 1,000 pounds of ballast was centered 36" behind the axel.
/ You need balast or you will trash your front axle!!!! really? #12
Yes, the 3,000lbs of torque would be working to raise the front axle. I never said it would remove 3,000lbs of load from the front axle.
Going off memory, the 3pt lift arms on even a little Ford 8N are 32" long, and anything that weighs 1,000lbs + should add at least a few more inches easily. In fact, many ballast setups (boxes, etc) have the weight behind the ball ends....I know my ballast block (steel) is that way, and I've seen lots that were similar. I'm not suggesting all tractors have lift arms that long, but clearly it's not a crazy measurement if they're that long on an 8N....I'm sure many modern CUTS have longer lift arms, or at least that long.
/ You need balast or you will trash your front axle!!!! really? #13
The front axle will support anything the FEL can lift, but when really digging in and pushing is where more weight on the beefy rears comes in handy. IMO digging in and pushing with a full load of dirt is where the front end gets stressed.
I would rather have the front tires slip than get torqued beyond normal limits.
/ You need balast or you will trash your front axle!!!! really? #14
I know that without the reliefs in the lift & tilt circuits, I definitely would over load the front axle. I built a set of "slip over the lip of the bucket" forks. The load was heavy and compounded with the extra length, I thought, 1 - the bucket lip would fail, 2 - the fork would fail, or 3 - break the tractor. I thought about raising the relief pressures, but, It probably saves me from breaking the tractor.
/ You need balast or you will trash your front axle!!!! really? #15
If you can use the loader safely in 2 wd then you have the weight about right. If light on weight and you have to use 4 wd the front axle has a very big load on it and you well be putting in bearings and gears. If axle housing brakes, then axle is not strong enough for the tractor. In 4 wd and the front is doing all the work sure well do a number on it.
/ You need balast or you will trash your front axle!!!! really? #16
You will of course not trash the axle with out ballast, but you will reduce the wear.
No guessing. The math is the math. No theory, just proven mathematical facts.
/ You need balast or you will trash your front axle!!!! really? #18
We had a big discussion on this last summer? With oversized and he did not believe it about ballast until he did a real test on the scales. Now he is a believer.
I think you have me all wrong. What about balast do you think I disbelieve?
/ You need balast or you will trash your front axle!!!! really? #20
I am sorry, I thought you did not.
"The reason I began doubting the validity of this is because the amount of rear ballast most people use is not enough to change the weight on the front axle substantially when a heavy load is lifted. I struggle to believe that a 10% difference in weight on the front axle is going to trash it."
MASSAGE CHAIR (A58214)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2000 Bobcat 863...
2019 FORD F-250 (INOPERABLE) (A60736)
2019 FORD F-250...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
