Generator question (household wiring to be more accurate)
   / Generator question (household wiring to be more accurate) #91
Leedscase,
Thanks for the reply. 702 is the correct section for this discussion. User permitted to manually transfer load. Nothing prohibiting generator connection to subpanel, as long as you have manually tranferred from utility.
So both the OPs and Aarons cases meet code if they follow the correct procedures. Aarons case with the kirk keys makes it fool proof, does the same function as the sliding lock.
As i said before, i don't do this, but don't believe it is against code, if your AHJ agrees. I use extension cords from generator to the load.
   / Generator question (household wiring to be more accurate) #94
Usually generator threads degrade into a pi$$ing contest over back feeding. Glad to see this one was different.
   / Generator question (household wiring to be more accurate) #95
Agreed.. and on that note I think I'll install a kirk key on my dryer plug and main breaker.... Should be ok right ???
   / Generator question (household wiring to be more accurate) #97
Save your self some money and just pull the meter!
SR
2017 Ford F-450 Crew Cab Mason Dump Truck (A55788)
2017 Ford F-450...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
