Generator question (household wiring to be more accurate)
   / Generator question (household wiring to be more accurate) #91
Leedscase,
Thanks for the reply. 702 is the correct section for this discussion. User permitted to manually transfer load. Nothing prohibiting generator connection to subpanel, as long as you have manually tranferred from utility.
So both the OPs and Aarons cases meet code if they follow the correct procedures. Aarons case with the kirk keys makes it fool proof, does the same function as the sliding lock.
As i said before, i don't do this, but don't believe it is against code, if your AHJ agrees. I use extension cords from generator to the load.
   / Generator question (household wiring to be more accurate) #94
Usually generator threads degrade into a pi$$ing contest over back feeding. Glad to see this one was different.
   / Generator question (household wiring to be more accurate) #95
Agreed.. and on that note I think I'll install a kirk key on my dryer plug and main breaker.... Should be ok right ???
   / Generator question (household wiring to be more accurate) #97
Save your self some money and just pull the meter!
SR
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2008 Lexus RX (A55758)
CATERPILLAR CS-563 ROLLER (A52705)
CATERPILLAR CS-563...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
BUNDLE OF 8" I BEAMS UP TO 49" (A54756)
BUNDLE OF 8" I...
