LED Garage Lights
   / LED Garage Lights #171
I put my 30 x 48 barn on 4 switches, 12 lights. Well, i will when it's finished.....
   / LED Garage Lights #172
Aaron, I wonder how the 20 watt LED lights would work to night light my flags on two 30' flag poles? They are supposed to be waterproof.
I am not sure it will be focused enough, they are a pretty wide angle light. Two of the 10 watt versions (LE® 10W LED Flood Lights, LED Outdoor Lighting, 100W Halogen Bulb Equivalent, 700lm, Waterproof, 6000K Daylight White, LED Security Light, Floodlight, Pack of 3 Units - - Amazon.com) have a wider beam than 3 PAR38 floodlights.
They would probbaly work if you could mount them on the top.
Aaron Z
   / LED Garage Lights #173
   / LED Garage Lights #174
   / LED Garage Lights #175
Those look interesting but, not sure that 10 watt LED will give me enough light for flags 30' above the ground?
   / LED Garage Lights #176
Has anyone tried using one of the Costco or Sam's fixture as a "plug-in" on a garage door opener? Our openers currently have a feeble incandescent that lights a little bit between the power head and the door, but the remaining 40 ft to the basement door stays quite dark. I was thinking of just using one of these
and plugging it in. Is the current draw of the LED fixtures in the same ballpark as an incandescent bulb or two? I once tried CFLs in a GDO, but the current draw was too low to properly cycle what was evidently a thermal timer circuit - the CFL never turned off!
I guess even if the current draw is very low, one of these
along with an incandescent would work.
   / LED Garage Lights #177
I'm anxious to see my 24x30' workshop when I take out my 6 double 2' 1" flourescents and put in 8 costco LED fixtures. Should be coming soon/
Will you put them all on one switch or alternate?
Not sure if you are addressing me, but I plan on 2 switches and then the florescents I plan to reuse directly over the workbenches with another switch. Nice thing about the Costco lights is the pull chain so they can be shut off if all aren't needed.
   / LED Garage Lights #178
I used two of the screw in plugins, ran extension cord to extend beyond the door edge, into a receptacle box to hold a LED spot light on each side of the door, which is very helpful lighting the shop while the door is open.
   / LED Garage Lights #179
I switched everything out like I wanted to. Now it looks like an operating room a split second after I flip the switch. It is now a pleasure to step into the workshop.
   / LED Garage Lights #180
I noticed that the latest Costco flyer has the Feit's on sale. IIRC, they were $23.99.
My two have been working awesome plugged into the GDO. I actually USE the "light" button on the opener remotes a lot now. Just the one LED shop light does a great job of providing enough light throughout the entire basement to safely navigate through. If I happen to accidentally leave one or both on all night, I don't really care.
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2011 FORD F-450 (A50854)
2011 FORD F-450...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
