LED Garage Lights
   / LED Garage Lights #162
The problem I have with the COSTCO LED's from the B&M is the extra cost of the add on's. Last time I also bought 2 bags of walnuts, 2 large plastic totes, and a bag of pecans. AND I WAS BY MYSELF! If SWMBO had been along it would have cost at least $200 more, mainly in groceries.
Tell me about it... one time I went in for some contact lens cleaning fluid for my wife and came out with a trampoline.
   / LED Garage Lights #163
Is that a T8 LED vs T12 Fluorescent? or a T5 LED vs a T8 Fluorescent?
I can see there is a big difference between T8-and T12 fluorescent.
Still cannot get over the lumens per watt of LED vs T8 fluorescent. Dont think there is much to gain going from T8-high output fluorescent with mirror reflector to a LED's
I have T8 bulbs in the barn (2 bulb "Cold Weather" fixtures from Lowes). Two of them about 15' apart in a 12x24 bay (middle section of a post and beam barn) are nowhere near as bright as 3 20w 6000k LED floods mounted ~14 feet apart in a 30x40 pole barn.
These are the floods: LE® 20W Super Bright Outdoor LED Flood Lights, 200W Halogen Bulb Equivalent, Waterproof, 1500lm, Daylight White, 6000K, Security Lights, Floodlight - - Amazon.com
The T8 bulbs are GE "Cool White" 4100k bulbs (2600 lumens each):
They light the barn up like so (one fixture ~10' behind the camera, one over the RTV):
For comparison, here is the light from 2 of the 20w LED fixtures (one is ~4' in from the car wall and 6' past the right edge of the picture, the other is ~8' behind the camera):
Aaron Z
   / LED Garage Lights #164
T12 Fluorescent, The LED tube says it is for T8 or T12 fixtures, but is the size of a T8.
   / LED Garage Lights #166
Will you put them all on one switch or alternate?
   / LED Garage Lights #167
These are the floods: LEÂ 20W Super Bright Outdoor LED Flood Lights, 200W Halogen Bulb Equivalent, Waterproof, 1500lm, Daylight White, 6000K, Security Lights, Floodlight - - Amazon.com
Aaron Z
Aaron, I wonder how the 20 watt LED lights would work to night light my flags on two 30' flag poles? They are supposed to be waterproof.
   / LED Garage Lights #168
Do they have drop in 8' LED bulbs that you just rewire out the ballast?
   / LED Garage Lights #170
Commercial we wire just about everything with two switches to have some control of level of light.
Even the smaller offices will have 3 bulb fixtures with one switch controlling the center bulb and the other switch controlling the two outer bulbs... giving three levels of lighting from the same fixture.
My shop is 22 x 30... it has three switches when I bought it... right bay, left bay and one for the work bench... mostly I just use the one over the bench which is at the far gable end.
As a side note... there are many times I have wished the garage with 24 wide instead of 22... sometimes even 24 x 36
I use it to park and maintain two Model A Fords and two Model T Fords... so 4 cars and the bench.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
