LED Garage Lights
   / LED Garage Lights #142
I ordered one of these this morning for a trial. 110V AC 36W Cool Pure White LED E26 E27 E39 E40 Mogul Base Light Bulb | eBay
36 watts / 3600 lumens and bright white (6000-6500 K) should be brighter than a 250 watt incandescent bulb. I have several bulb sockets, about 12' above floor, in the side bays of my workshop. I have some 120 watt equivalent CFL day light flood lights there now but, they take a while to get bright and still don't produce as much light as I would like.
If a 60 watt light bulb is equivalent to a 6-8 watt LED this one, @ 36 watts, should be equivalent to 270-360 watt incandescent?
This should be a good improvement, if it works. Will report back later after its installed.
   / LED Garage Lights #143
LED tube vs flourescent tube.
   / LED Garage Lights #144
I have one of those cheapy pocket calculators with a solar cell.
Immediately noticed how much better it works under LED light...
Not scientific but very noticeable.
   / LED Garage Lights #146
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=457583"/> LED tube vs flourescent tube.
Was it cold when that was taken? There isn't nearly that big of a difference with mine.
   / LED Garage Lights #147
Costco has the 4foot 2-tube LED shop lights now for $24.99. I bought 7 of them. VERY happy with their performance. They have a plugin and a pull-chain switch. They must be about 50% brighter than 4-ft Fluorescent tubes.
I've been using one (2 tubes) under my truck, on the ground, you sure can see every little part looking up. And no shadows. And the 'tubes' are plastic so if something falls on it....well I can't say how strong it is ....... but it's plastic.
   / LED Garage Lights #148
Sodo, would you mind taking an AM radio and perhaps tune in between stations and start up one of these lights nearby. Or tune to a weak but readable station and repeat the experiment. I would like to know how much if any detectable Radio Frequency Interference that they put out. If you have a shortwave radio reciever nearby, (3 to 30 Mhz) that would be great to test with too. Thanking you in advance..
Every Cree bulb I have tested, does not seem to have any RFI.
   / LED Garage Lights #149
Today I replaced 4 double tube florescent shop lights with led shop lights IT is definitely much brighter. The whole place felt brighter and cleaner. I bought 6 of these lights and installed one of them in the garage a year and a half ago. Installed 1 in the garage when I first bought them, and the others sat in their box until today. I put the one I didn't use in the back of the shop as a spare in case one of them craps out, but the one I have had in the garage has been used every day and has been fine. They come on almost instantly and are very bright.
I've got uninstalled "spares" also. I think I may have posted this before - my mongrel HF/HD LED worklight
attachment.php
I'm pretty sure you are safe from shattered glass!
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2019 Allmand...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
