LED Garage Lights
   / LED Garage Lights #131
Nope! I put Costco 6 qty of 4ft fixtures (2 bulbs each) with 4100K in my garage/shop and they are a nice clean white. Not yellow at all.
How about a comparison picture?
   / LED Garage Lights #132
I already posted earlier in this or another LED thread. But here you go! No question, much brighter visually and I measured and posted the lumen output and big difference also.
   / LED Garage Lights #133
Let me sum up what I think you said, and please correct me if I made some wrong assumptions in your presentation.
I think you are saying that changing out the old 8 fluorescent tubes with your new LED replacement tubes AND wiring around the ballasts is well worth doing from a money saved and light intensity gained prospective. BUT replacing your 4 foot T8 tubes with the phillips direct replacement LED tubes and re-using the old existing ballast is a money loser, but you didn't mention if these were brighter or not than the original T8 tubes.
Am I correct?
Yes; Installing the new LEDs and bypassing the ballast reduced consumption and the increased light output was very significant.
Also correct in that the direct fit LEDs from Phillip's used more power and the light output was no better than the CFL's.
90cummins
   / LED Garage Lights #134
Am I correct?
90cummins
Got It :thumbsup: thanks.
   / LED Garage Lights #135
If you have a low ceiling it is better to have lights without reflectors. The lighted ceiling reflects light and looks higher. A low dark ceiling makes you feel like you are in a cave. If you have a high ceiling then you want reflectors. You want all the light reflected on your work, and you don't worry about a ceiling that looks like the night sky.
People in cold climates like "warm" lights to feel warmer. People in hot climates like "cold" light, because it makes them feel cooler.
Compare LEDs with a fluorescent tube that has at least 100 hours, but not needs replacement. Some think a fluorescent tube is still good as long as it lights up.
Over time fluorescent lights lose over 70% of initial light.
In workplaces with bright windows you need more light than in workplaces without windows.
I would look for LEDs to get rid of ballasts. By the way, ballasts do not fail in Europe ( 50 hertz 230 volt systems )
Just my thoughts.
   / LED Garage Lights #136
I replace 1 or 2 T8 ballasts every week somewhere in the Hospital...
Also have lights that are not switched... on 24/7 with a few that have been on 20 years last December... still enough light to do what needs to be done.
The T8 that don't last are the ones turned on and off 50 times a day... the ones that stay on last a VERY long time.
Also have an assortment of Compact Fluorescents... knock on wood... not a single bad ballast in 20 years.
   / LED Garage Lights #137
Today I replaced 4 double tube florescent shop lights with led shop lights IT is definitely much brighter. The whole place felt brighter and cleaner. I bought 6 of these lights and installed one of them in the garage a year and a half ago. Installed 1 in the garage when I first bought them, and the others sat in their box until today. I put the one I didn't use in the back of the shop as a spare in case one of them craps out, but the one I have had in the garage has been used every day and has been fine. They come on almost instantly and are very bright.
   / LED Garage Lights #138
If you have a low ceiling it is better to have lights without reflectors. The lighted ceiling reflects light and looks higher. A low dark ceiling makes you feel like you are in a cave. If you have a high ceiling then you want reflectors. You want all the light reflected on your work, and you don't worry about a ceiling that looks like the night sky. Some think a fluorescent tube is still good as long as it lights up.
I definitely agree... The Costco LEDs do not have reflectors and I mounted them direct on the ceiling. Now I want to tape and mud and paint my ceiling white to improve the reflection after noticing how much more effective in spreading the light. I am also enjoying not hitting the old fluorescents fixtures (I lazily hung by chains) when I am swinging around a 2x4 stud or some other long piece of wood or pipe, etc. :dance1:
I also have noticed the 'fade' of the fluorescents as well as halogens over time... it will be interesting to see how the LEDs do over time and also how LED technology advances in the coming years.
Since the Costco price was the same for LEDs with or without fixtures, I didn't hesitate and hassle with ballast removal. The instant on in the cold weather is wonderful too!
   / LED Garage Lights #139
90cummins
I've gradually been replacing 4' florescent tubes with direct fit LEDs from Costco. Don't know the brand, but one tube is as bright as both of the old florescent tubes put together, and when both LEDs are installed the light is much much brighter. I've not done any measurements to quantify the difference, but it's much easier to see what's going on in the shop with the LEDs.
There's not much difference in price between the direct fit LEDs and the LED fixtures, at least at my local Costco. I rewired my florescent fixtures to a junction box on one end that houses a household electrical outlet, and use lamp cord with a household plug on each end to daisy chain the fixtures together. NO the installation DOESN'T meet code, but it sure makes it easy to move fixtures around when the need arises. That and the fact that installing the direct fit LEDs takes only a few minutes, was enough reason for me to go that route rather than replace the fixtures. I wasn't aware that the LEDs consume more power, but I don't run them all day, every day, and don't expect I'll notice much difference on my electric bill. If I was starting from scratch, though, I'd go with the LED fixtures.
   / LED Garage Lights #140
I got a couple of the Costco shop lights today. Just to compare and see for myself whether I should change. They are much brighter than my existing fluorescent shop lights. Huge improvement. I like that they can be mounted directly, rather than use hanging chains.
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
Unused 2025 CFG QNT50R Mini Excavator (A49461)
Unused 2025 CFG...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
