Your towing rigs and trailers
/ Your towing rigs and trailers #2,292
A lot of 10 y/o trucks around here don't look anywhere near that good !
Rgds, D.
Thank you.
I spray under the truck with oil every year (for the past 20 years that I have owned it).
Still in great shape. No rust and it runs in the salt and calcium they put on our roads in the winter.
Vince, what type of oil do you use? I've been wanting to have this done on my 2015 3500 but they charge like $700 but the salts here really ruins the underside's of vehicle's too. I guess they'll touch up the underside yearly though if you bring in in for nothing.
Matt
/ Your towing rigs and trailers #2,294
Matt
I have always just used used motor oil.
I'm considering trying some Fluid Film next year when I spray it.
Several places around here that oil vehicles have been using Fluid Film and seem to like it.
/ Your towing rigs and trailers #2,295
Matt
I drilled a hole in the door jam of each door so I can spray inside the doors, then just cap the hole with a plastic plug.
I do the same thing in the jam so I can spray up in the cab corners.
I also drill some holes inside the bed so I can spray in around the beds fender wells.
/ Your towing rigs and trailers #2,296
Hauled this home today. Clearing a lot next to where I work, our guys doing the demo work on 2 old houses, and a couple soft maple trees. Excavator operator didn't mind doing dropping these logs on my trailer instead of in our dump trucks...
Going to my buddies sawmill on Friday!
/ Your towing rigs and trailers #2,297
Great info on the "undercoating" of oil.
I recall Paul Short discussing how he uses fluid film on his 1993 chevy, and it's spotless.
My 1995 chevy was NOT spotless.
I just got a 2014 chevy, so I'm suddenly interested in how to prevent rust again.
Anyway, I was going to dig up that youtube video try to figure out exactly what he was doing. Now, I don't have to.
Do you just put it in a mister bottle? Do you have to thin it out at all? Does the truck end up smelling all the time because of the oil?
I have GOBS of used oil. The new truck is a diesel, so once I change its oil I'll have GOBS and GOBS and GOBS of oil.
/ Your towing rigs and trailers #2,298
My vehicles will smell for a short time till any oil I got on the exhaust system gets burned off. But they do not smell for long.
I use an undercoat sprayer ( think it was around $60) and air compressor for spraying the oil.
Fluid Film offers a spray gun for spraying their oil, but I'm sure an undercoating sprayer would work fine for that also.
I never thin the oil. My undercoat sprayer sprays anything I put through it very well.
/ Your towing rigs and trailers #2,299
Cool. Thanks for the info! Never heard of an undercoating sprayer.
I read in a truck forum that spraying fluid film on a GM frame harms/softens the coating that GM has on it.
On my truck, 2 years old, the frame has rust (spots) on it....
pondering some POR-15 on the frame.
I suppose I'm wandering way off topic.....................
/ Your towing rigs and trailers #2,300
From what I've seen I'm not convinced the factory coatings work that great anyway.
If it was mine I would spray it.
Oiling makes a huge difference.
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2001 John Deere 6210 (A60462)
2001 John Deere...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
