Best deck building software? (CAD based)
/ Best deck building software? (CAD based) #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Built a few decks in the past but this one will be much bigger and more complicated. 3 levels with the highest being about 10ft off the ground and one level built to support a future hot tub. I'd also like to be able to estimate a build list to estimate cost.
Anyone have experience with a consumer grade software package for this purpose? (eg Home Designer etc)
/ Best deck building software? (CAD based) #2
I'm old school. I still like to use graph paper and a calculator
/ Best deck building software? (CAD based) #3
Look at SketchUp. It is free and easy to use. Does 3D and rendering.
/ Best deck building software? (CAD based) #4
Plus 1 for SketchUp. I've designed several outbuildings, a kitchen and bath remodel, and a ton of smaller projects and it does everything I would ever need and then some. There's also the huge plus of it being free so if you don't like it, no loss. For tutorials, check out the harwood podcast channel on youtube. They break it down into simple steps to make using it quick and easy.
/ Best deck building software? (CAD based) #5
Never saw software that could build a deck, but maybe you can print one with a 3D printer.
For design, paper and pencil is the cheapest and fastest. For cad i prefer microstation, than autocad. They all have a learning curve. Sketchup a little harder, but the price is right. Chief architect isn't bad either.
Thanks for the input y'all but I was hoping to find someone who had used one of the commercial software packages to design a deck. Sketchup is great but I'am looking for more "functionality."
/ Best deck building software? (CAD based) #8
If you want a full grown CAD package then download Draftsight. It is free and works basically the same as Autocad.
DraftSight - Dassault Systèmes
I was going to suggest this as well. Had to switch to Draftsight from AutoCAD over a year ago. It’s almost a clone to AutoCAD but free rather than costing thousands. It’s not quite as “fluid” for those used to AutoCAD, but for a new user it’s great. I haven’t tried its 3D capabilities however. I have much better 3D software and do all my design in it. But at over $20k/year, it’s not for the DIY guy. :D
/ Best deck building software? (CAD based) #9
I have worked with AutoCAD but why would you need something that can design a city or space station for decks.
Thanks guys but I'm not smart enough for those professional CAD programs. Definitely just looking a consumer grade such as 'Home Designer', 'Chief Architect', 'Punch', 'TuboCAD' for dummies... Etc.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 GMC Arcadia SUV (A61569)
2017 GMC Arcadia...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
832706 (A61166)
832706 (A61166)
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
