Kioti CK2610 TLB
   / Kioti CK2610 TLB #11
I have a shuttle shift and never have that problem !!
Whenever I use someone else's machine with shuttle or gear to work on a pile of dirt or gravel, I really notice the difference. With HST, I can nose in and out of a pile with one hand on the wheel and the other on the loader valve, no interruptions. With the others, I have to remove a hand from somewhere to change direction. Do that a few dozen/hundred times a day and it feels frustrating. I'll never go without HST for loader work on my own tractors!
   / Kioti CK2610 TLB #12
Personally I like the shuttle.
A hydraulic reverser/power reverser would be nice though.
   / Kioti CK2610 TLB
Just got the phone call, will be here soon.
I hope the Industrial tires do ok in he snow, it is snowing now. Nothing like having delivered in the snow....
   / Kioti CK2610 TLB #14
How do you run steering, loader/3PTH, and shuttle all at once? Do you just kinda juggle the wheel and shuttle with one hand?
   / Kioti CK2610 TLB #15
Industrials are nothing to write home about in the snow. If you have flat ground they are not too bad. if you have icy hills.. They suck. I have them. and prefer Industrials overall, as I do mostly loader work. They are the most rugged, but are a compromise on traction. I run chains, but a lot of guys have had pretty good luck grooving the Industrials. You can read about it here.
   / Kioti CK2610 TLB #16
The only time you need to take your hand off the wheel for the shuttle is for the 1 second it takes to forward/reverse.
If you are at or near a dead stop to forward/reverse where are you trying to steer to when not moving ?
   / Kioti CK2610 TLB #17
Very true, now that I think about it. Probably a mind thing with taking one's hand off the wheel. The only shuttle I've run is my neighbor's JD (actually power shuttle), and I was very new so always brought it to a full stop and used clutch while shifting. Using it to push the dead H in the dark and cold was my first experience on a modern tractor, and the one that lead to the Kioti. I got off the 4510, looked at the nonfunctional H, the unplowed driveway, thought about power steering, 4WD, and the loader, and decided on the spot that a modern CUT was in the near future.
   / Kioti CK2610 TLB #18
Congrats on the new ride! That sounds like a heck of a price too! That's what I paid for my CK2510HST TLB last year. What was the difference in price to get the HST?
   / Kioti CK2610 TLB
Price difference was $1400! More than I was willing to pay, now if it was $700 I MIGHT of had it. But on the Kioti the HST pedals are in a weird spot and I didn't like it.
I will post some pictures tomorrow once I figure out how to do it and take some in the daylight.
Got it with 1.1 hours on it and now has 2.6, I played a little and started on a Hemlock stump I need out of the way. It does good on anything smaller than my wrist, but the larger roots will need to be cut with a saw of sawzaw. Either way, way better than digging out by hand or paying for someone to remove them, I can't afford that now (Darn tractor payment now)...:smiley_aafz:
On the loader I looked in the specs book, it is a little lighter than I was thinking but still stronger than anything that I looked at, 1252lbs at pins. But we all know specs are actually a bit light so I feel it will actually do a bit more, but will have to keep BH on or get some ballast box made.
All and all I am a happy new owner so far.
I do have one question, I smelled hydraulic fluid? Is this normal once it warms up, I looked at what I could in the dark with flash light and didn't see anything off. But I was also working in snow and there was water spots everywhere.
   / Kioti CK2610 TLB #20
Congrats on the new tractor, can't wait to see some pics! I am also a fairly new tractor owner, got my ck2510 back in November, and I have also had that hydraulic smell. Has made my paranoid from time to time, but all seems well.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
Mower King Brush Cutter (A53317)
Mower King Brush...
Gorman Rupp T4A3-B 4in Centrifugal Dewatering Pump (A55851)
Gorman Rupp T4A3-B...
2005 EZ-GO Cart (A55853)
2005 EZ-GO Cart...
