5085e questions
/ 5085e questions #1
sacarmic
Member
Deere 5085e, 3320
So, I just received me new 2013 5085e (it was NOS) with cab. Have always had an open station tractor with normal transmission, there is a lot to get used to, especially that power reverser! :)
One thing I'm finding a little awkward to get used to is having to go around to get into the cab to make adjustments to the loader controls or 3pt hitch arms when attaching implements. I was looking at the cab and it really looks like you could add hinges to the RH door to open it up to access the controls easier. I see in the parts catalog that the RH door parts are available. Anyone on here ever convert their RH door to open? Just curious.
Also, I put mounts on it for my 553 loader that I already had. The arms travel up and down really well, and the tilt down works great, but the tilt up is really slow. Any thoughts on what the issue could be? Only thing I could think of was maybe air in the hydraulic line? IF so, how would i get it out.
Thanks,
Scott
/ 5085e questions #2
Likely is not air, as air gets pushed out real quick. May try disconnecting the quick couplers and reconnecting them. Sometimes they don't seat well... just a thought.
And tilt down is faster than tilt up, with that regenerative circuit for fast dumping.
/ 5085e questions #3
You can get a RH door kit from JD. The hyrdraulics on the 5E's are very slow, compared to other modern tractors.
/ 5085e questions #4
I would think 15.9 GPM @ 2828 psi wouldn't be real slow.
/ 5085e questions
Maybe it is the seal on the couplers. FYI, is it noisier when I tilt up, so that is what gave me the thought nothing is going on. The arms going up and down are real quick though, so that makes me think something else is going on.
/ 5085e questions
Also, the top bend in the vertical exhaust sure seems right in the field of view. Seems like it should be higher for the cab model. Anyone put a corner exhaust on theirs? Thinking about that upgrade as well.
Thanks,
Scott
/ 5085e questions #7
I noticed a huge difference going from the 15.9 gpm with my Deere to 29 gpm with my MF. The Deere was loader was VERY slow and weak compared to my Massey.
/ 5085e questions #8
/ 5085e questions #9
Matt
Apples and Oranges comparison. Double up the purchase price will buy some extras...
sacarmic
Find or make up an oil pressure gauge that you can snap into a quick coupler and check your oil pressure.
/ 5085e questions #10
Matt
sacarmic
lol, surprisingly there wasn't much of a difference in purchase price between a JD 5100E and a MF 5612. If I didn't get a deluxe model with suspension and moved down to 100 or 110hp the price would have been about the same. It is an apples to oranges comparison, when you compare specs that's for sure.
/ 5085e questions #11
I have ""no doubt that almost doubling GPM output of hyd pump"" will definitely decrease FEL cycle time & improve performance!
/ 5085e questions
Well I found the problem, looks like the tilt outputs color caps had been reversed. I connect them correctly and everything works great now.
/ 5085e questions
now one more question for you all, It has the normal exhaust on it, but I find it gets in the way looking at the loader. Do any of you who have one of these have the A-post exhaust? If so, do you like it off to the side?
Thanks again
Scott
/ 5085e questions #14
I had the normal exhaust on mine as well, in the way, turned loader black from soot and couldn't run with the loader up for too long for fear of melting hoses. My new tractor has corner post exhaust, way better! You don't even know its there. If you can upgrade to the corner post exhaust for a few hundred bucks or less I would say it's worth it. Should probably be standard equipment anyway.
/ 5085e questions
Thanks for the tip. Since the pie comes so low on the corner exhaust how do you tun your hydraulic hoses so they don't get so close?
2007 PETERBILT 357 (A67714)
2007 PETERBILT 357...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2015 Honda Accord Sedan (A66738)
2015 Honda Accord...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
2009 CATERPILLAR CS56 SMOOTH DRUM ROLLER (A65056)
2009 CATERPILLAR...
