Tires Tire lost pressure, separated from rim
   / Tire lost pressure, separated from rim #21
Are you sure they didn’t spray ether in there first? Doesn’t seem like a firecracker would be nearly enough “umphhh” to seat a bicycle tire, let alone anything bigger.
No, he had the match for the fuse right by the bead and if there was either in it, it would have wooft. The video started with him putting the thing in the tire which wasn't clearly shown, so maybe it was an m80 or something. I have to go check it out better.
   / Tire lost pressure, separated from rim #22
   / Tire lost pressure, separated from rim #23
Maybe the TBN research team has some experience..:thumbsup::thumbsup::D:D:D
   / Tire lost pressure, separated from rim #24
   / Tire lost pressure, separated from rim #25
So what to use for a bigger tire? A hand grenade? There is a youtube video CLEARLY showing that a regular car battery is actually full of hundreds of regular AA cells. Who knew?
   / Tire lost pressure, separated from rim #26
I fought with some super singles once for days trying all manner of tricks to get them back on the rims. I finally used starting fluid and that would be my first choice from now on. I used a ten foot long stick and various personal safety gear. But I am not suggesting YOU do this.
I know a friend who put some air in a small (rotten) lawn and garden tire. It exploded on the bench, ripping open his hand and messing up the bones. Blew a hole in the ceiling. If he had been leaning over it, he would be dead. Tires of any size can be extremely dangerous and deserve the utmost of respect and caution.
1+ on the respect and caution. Had a friend loose hearing in one ear and lots of stitches in his scalp ,when a strap he had around a tire to seat the bead broke and hit him.
   / Tire lost pressure, separated from rim #27
No one, because it's not true.
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2023 JOHN DEERE 325G SKID STEER (A52707)
2023 JOHN DEERE...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
2013 KENWORTH T800 FLATTOP SLEEPER (A55745)
2013 KENWORTH T800...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
