Anyone built there own weight box for a three point?
/ Anyone built there own weight box for a three point?
I added a cement cylinder to ride on my box blade as my weight box. My 3720 needs 1200# for safe operation with the 300CX loader. Too hard to find or make that big a box. My Frontier box is just over 500, and I filled a 12" Sonotube with rebar and concrete for an additional 400+ lbs. it has chains connected to the center rod that keep it on the BB. With the moment sitting on the back of the BB, I think I have enough counter weight. Seems to be working, will update in a few months.
Sounds like it would help with the back blade too. Could you post some pics?
/ Anyone built there own weight box for a three point? #62
I fabbed this one up to be compact and adjustable. The frame weighs 150lbs and each piece of rr track weighs 100lbs for a total of 650lbs. I have 5 more pieces of track or 500lbs if needed. The 650lbs has worked out perfect so far for my B2650.
/ Anyone built there own weight box for a three point? #64
Here is a photo before I loaded it up. Will post one loaded later.
/ Anyone built there own weight box for a three point? #65
i LIKE THAT iDEA.I have been thinking how to make something like that for my snow blower. I could take it off when Im using the blower and then have it back on when I need the traction weight
/ Anyone built there own weight box for a three point? #66
I didn't build this one but modified a JD box I found on CL, I started by adding RR rail runners & a 2" receiver tube that is bolted to the box. 1071.JPG Then, an old galvanized grainery door for a tray over the scrap iron & lead weight inside, with two plastic conduit tool holders. 1079.JPG A chainsaw sleeve made from 1/4" sheet plastic is on the other side. HPIM1260 - Copy.JPG Threaded lower 3-pt pins were added for more clearance when loading the tractor on a trailer & some small "D" rings for tie-downs.
/ Anyone built there own weight box for a three point? #67
I didn't build this one but modified a JD box I found on CL, I started by adding RR rail runners & a 2" receiver tube that is bolted to the box. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=455802"/> Then, an old galvanized grainery door for a tray over the scrap iron & lead weight inside, with two plastic conduit tool holders. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=455803"/> A chainsaw sleeve made from 1/4" sheet plastic is on the other side. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=455804"/> Threaded lower 3-pt pins were added for more clearance when loading the tractor on a trailer & some small "D" rings for tie-downs.
NICE👍
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2014 PETERBILT 388 CAR HAULER (A59904)
2014 PETERBILT 388...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
