Max28 and cold Weather
/ Max28 and cold Weather #41
Mike, just out of curiousity i see you have some Kubotas in your profile. Will those start under same conditions and also what made you change brands? Price? Probs with Kubotas? Or dealer? Best of luck
Max28 was the right size tractor at the right price. It spec'd well and basically is a decent tractor.
Your expectations have to be a little lower with a low priced tractor vs. a big consumer item like anF150, etc.
Contact Us | Mahindra
Contacted Mahindra by phone.
Was told they do not provide technical support and to contact Gary Equipment 315 699-8072 Error
I was nice, but whomever the receptionist tried to pass me thru to did not want to speak to a Mahindra owner.
The many Kubota's I am familiar with have starting problems when they have bad fuel, Clogged filters or weak/ dead batteries. Otherwise they start.
I do know 3 other Mahindra owners, 40 HP and above, and think they do not have starting issues.
/ Max28 and cold Weather #43
mike69440; Contacted Mahindra by phone. Was told they do not provide technical support and to contact Gary Equipment 315 699-8072 [url=http://www.garysequipmentco.com said:
Error[/url]
True, only Dealers can call for tech support.You can call your dealer and get the DSR involved but they are currently conducting service schools and will be hard to reach. Did you check the glow plug power, key on no GP light? I still suspect you have a GP controller or sensor issue.:confused3:
Mahindra better not get into IT!
Did you check the glow plug power?
Not yet dark & cold when I get home, I'll probe this weekend.
Key on no GP light?
The GP light works, stays on for 10 seconds.
Could be. I really have better things I should be doing.
Tonight I turned on Ignition and Let GP do one cycle. Temp is in high teens.
Light went out, I left ignition on for five minutes on less while I made a quick check of the horse barn.
Then I tried to start tractor for a few second crank, no start.
I cycled the GP again and it coughed to life.
GP must be working somewhat as I did not crank it enough to heat up the combustion chamber?
/ Max28 and cold Weather #45
Let go light cyle on and off. Then do it again. Or even three times if needed. Then turn it to start. The engine should not need more than a turn or two to start.
/ Max28 and cold Weather #46
I've done the glow plug cycle 3, 4, 5 plus times on mine in the past. Then finally it will cough to life. But this is usually only when it sits outside in 10-20 degree weather.
Right now mine is in a 32-ish degree garage and I just went out and tried to start it and it was a no go.
I even did the cycle on-cycle off-cycle on dance for 5 times straight, still no go. My multi-meter is dead so if I can find a 9-volt I'll go back and see if I'm getting any voltage to the glow plugs.
/ Max28 and cold Weather #47
I went back out and fiddled with it. I pulled the connector off the glow plug rail and then put it back on. Checked it with a multi-meter and I was getting 10.5 volts on the rail while the glow plug timer ran. Battery voltage was 12.5, not sure what it was with the glow plugs on, I didn't check.
Cycled the plugs three times and then it sputtered to life.
bamboozled
What is your tractor model?
I sent inquiry and this trread to Mahindra Coportate email general contact form @ Contact Us | Mahindra
Good Info for all:
http://info.bm.ee/tech/Gendata/T16/ENGINE/33522049401.pdf
http://personalpages.tds.net/~eflan...l for Mitsubishi SL-Series Diesel Engines.pdf
/ Max28 and cold Weather #50
I just noticed this section in the document in the top link you posted, specifically step 1. I usually leave my speed lever at idle or slightly above when trying to cold start:
5.2.1 Engine with glow timer
1. Move the speed control lever to the HIGH
SPEED position.
2. Turn the starter switch key to the ON position
and make sure that the oil pressure, coolant
temperature, and glow plug indicators are lit.
See Table 2 Starting Aid Chart for heating
time.
3. When the glow plug indicator goes off, turn
the key to the START position.
4. Release the key when the engine starts. The
key will return to the ON position when
released.
5. Move the speed control lever to the idling
position.
/ Max28 and cold Weather #51
I went back out and fiddled with it. I pulled the connector off the glow plug rail and then put it back on. Checked it with a multi-meter and I was getting 10.5 volts on the rail while the glow plug timer ran. Battery voltage was 12.5, not sure what it was with the glow plugs on, I didn't check. Cycled the plugs three times and then it sputtered to life.
I bet dollars to donuts it's a glow plug issue week plug or plugs
Sent from my iPhone using TractorByNet
SPEED position.
time.
released.
position.
Now isn't that Special!
If you read Page 41 of the Max28 IOM, it states to put the throttle lever in the low speed position. Max28 manual states also that the GP light will blink for 30 Seconds after start. (Never seen this on my tractor) So much for operating manuals??
I will be pleasantly surprised if Mahindra responds to my Inquiry.
The good new s is that finally I got the O2 Sensors and exhausts back on my 03 Mustang Cobra today after being up on blocks since mid summer.
When I fired it up quite a bit of Dog Kibble and Acorns come blasting out the exhaust. Cat needs to go out to garage more often!
/ Max28 and cold Weather #53
I checked my battery voltage with the glow plugs on, it dropped down to 11.5 then came back up to the usual 12.5 once they timed out. I haven't tried a cold start yet today, I'm going to try the high throttle start here shortly.
/ Max28 and cold Weather #54
My own 2216 was sluggish catching this morning and not that cold out. Sounded like it was running on 1 cylinder until it caught. Decided a check of the glow plug resistance might not be a bad idea (original glow plugs in a 2008 tractor). The nut that held the ring connector on the main wire was snug, but the two nuts that retain the rail that feed the other two glow plugs weren't exactly what I'd call tight. Resistance of the glow plugs was about 0.6 ohms with the meter I had (service manual showed 0.55 ohms), so close enough. No evidence of any arcing on the rail, so don't know if they were making a good connection or not.
Might not be a bad idea to check the nuts on the glow plugs to make sure of tightness.
It took about 5 minutes and a dozen or more GP cycles to get the Max28 Started. It was 13 F. I did not rush it and each crank was less than 5 Sec so as not to beat on the starter. It so happened when it started I had it at full throttle but the motor did not race, no throttle response for a few seconds, but yet it seemed like it was firing on all 3 cylinders.
When I do the fluids I'm going synthetic on all.
/ Max28 and cold Weather #56
It took about 5 minutes and a dozen or more GP cycles to get the Max28 Started. It was 13 F. I did not rush it and each crank was less than 5 Sec so as not to beat on the starter. It so happened when it started I had it at full throttle but the motor did not race, no throttle response for a few seconds, but yet it seemed like it was firing on all 3 cylinders. When I do the fluids I'm going synthetic on all.
i feel for you Mike, that must be so frustrating.... We buy tractors for simplicity and reliability among other things. I for one am not brand loyal so if my Kubota did that and i couldnt fix it, it would go bye bye! Btw i hadnt started my bx in over a month in an unheated garage , 5 seconds of glow started right up. Was 18 degrees. Best of luck and you know i bet you would get a good trade in towards a new bota:))
/ Max28 and cold Weather #57
warmed into tthe high 30's today and glow plugged many times and no start - more glow plugs any times and no start and more and then said F&^& it! will charge tomorrow when even warmer and try to start before rain come in.
/ Max28 and cold Weather #58
Below 32 F your GP light should be flashing after start up. Thats why I suspect you have a glow timer or controller issue. I have several MAX units in the area and with this last round of snow and cold no one is calling about not being able to start there tractors.:confused3:
/ Max28 and cold Weather #59
if directed at me - i cannot get it to start to see it flashing related to a statement in the thread i did not read. sorry
Re: Max28 and cold Weather, mahindra reponds!
It was nice that Mahindra cleared the way for me with a local dealer for service as I did not purchase it there.
I just had a conversation with the service manager.
I was told there was a fuel adjustment at start=up that has been an issue and that occasionally the glow plug resistance are outside of spec.
I'll cart it over to the dealer Saturday if mother nature does not conspire against me.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
1998 Link Belt HTC-8660 60 Ton Hydraulic Truck Crane (A60352)
1998 Link Belt...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2 Door Refrigerator (A60352)
2 Door...
