oldpilgrim
Elite Member
oldpilgram, its a Mitsubishi S3L2.
That's what I thought, the same as in my 3016, just tuned down a little I think.
Weird that it should run so differently.
Did yours come from Morgan? I got mine at Westville in Taunton.
Yes I did. Haven't been to Westville. I'll have to check them out when I'm around that area.That's what I thought, the same as in my 3016, just tuned down a little I think.
I also have a 3016 I left mine outside last night do to a family emergency I woke up this am and went to go start it to bring it in to the garage cycled glow plugs twice started in 2 to 3 seconds rough for 5 to 6 seconds and smooth out temps this am was 18 windshield temp about 4
Sent from my iPhone using TractorByNet
For the heck of it tonight when I take the dog out I'm going to cycle the glow plugs 3-4 times, then crank for 5 seconds then cycle GP's some more to see if it lights up in below 10F weather. Tractor is stored under a lean to
Mike,
Are you running off road fuel? I have found that the Mitsubishi diesels, in the Mahindra tractors, do not particularly like off road fuel. I have convinced some of my customers to switch to highway fuel and it helped the problem.
Low sulfur straight from the Shell stationMike,
So Like once before i let it sit 2 minutes with the ignition to run position, without GP light.
Then I turn the key to crank and it starts right up?
I did a bit of plowing cleanup with BB to charge up battery and warm motor and called it quits for tonight.
This is very weird.
So Friday, I'll try just one GP cycle and let it sit with ignition on for 2 minutes, then crank over engine to see what happens.
There is no difference between off-road and highway diesel except for dye. I think you guys are imagining things!
I was just too windy and got back late last night so I tried it tonight. 19 F and no wind.
I cycled the glow plugs 3-4 times, then crank for 5 seconds then repeated the 3 X cycle GP's two more more times. No Start.
This is very weird.
13 Years of experience, with Mahindra tractors has proved this to me.
It seems like the glow plug function does not match the description in the owners manual, this is what I've found as well but I only did the test once. I may pull mine out of the garage this weekend and do the same test after letting it sit outside overnight.
I don't suppose you have tried calling Mahindra tech support to see if they have seen similar behavior?
I hate to break it to you, but you really are imagining things (unless Mahindras can't tolerate red dye). There have been quite a few topics on TBN where this has been discussed, and Google has many links too. It's all the same stuff.
