'15 F-450 Pickup
/ '15 F-450 Pickup #81
So how many miles have you put on it in almost a year and a half?
/ '15 F-450 Pickup #83
Hey, thanks, good to know. I'm 80% going with a new truck. Called on one in Texas today, they knocked 200 bucks off the price and said that's bottom dollar. They bought it off a dealer in Kansas, wish I knew what they paid for it. 3000 miles f450 KR. Asking 64,900. Think I can do a bit better.
Thanks again.
/ '15 F-450 Pickup #84
Hey, thanks, good to know. I'm 80% going with a new truck. Called on one in Texas today, they knocked 200 bucks off the price and said that's bottom dollar. They bought it off a dealer in Kansas, wish I knew what they paid for it. 3000 miles f450 KR. Asking 64,900. Think I can do a bit better. Thanks again.
You may want to look at other brands that sounds really high for a used truck. I bought this 3500 C&C ram with a custom built dump bed with fold down sides and gooseneck hitch for much less and its new. Oh and I custom ordered the truck too.
/ '15 F-450 Pickup #85
You may want to look at other brands that sounds really high for a used truck. I bought this 3500 C&C ram with a custom built dump bed with fold down sides and gooseneck hitch for much less and its new. Oh and I custom ordered the truck too. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=454489"/>
I'm sure a gas F450 would be much cheaper to than the diesel one he is looking at. I see you have the Hemi.
/ '15 F-450 Pickup #86
Well that king Ranch trim level adds $15-$20k to the price over the same truck in XLT trim.
Scoutcub, do you need it to be F-450? I just bought '16 F-350 for about $14k under MSRP.
/ '15 F-450 Pickup #87
Not interested in other brands. I've got a 06 f350 Dually KR and its treated me extremely well. I work it pretty hard, pulling excavators, dozers and skid steers. If I go new, want to step up to the beefier 450 and 6.7. I'm in no rush, so will wait for the right deal on a 15 or 16.....
/ '15 F-450 Pickup #88
Yeah but you also have to factor in the custom built dump bed that close to the price of the diesel. I got the 6.4 hemi thought I'd try it out I've got other trucks with the 6.7 CTD. I don't want to list prices but I'd never pay in the 60's for a truck. I bought a 5500 CTD 4x4 and custom box body for quite a bit less than 60K. Just saying look at other brands and get the best truck for you.
/ '15 F-450 Pickup
The F-450 pickup only comes as a diesel 4x4 crew cab. Trim levels run from an XL to the Platinum. You can still get the V10 but only in a chassis-cab. Get the F-450 KR pickup, you won't regret it.
/ '15 F-450 Pickup #91
The 6.7 diesel has an amazing amount of power, even more than my '12 had. This engine is rated at 440 hp and 86o lb/ft torque. Mash on it hard and the rear tires try to break loose even in third gear. The traction control kicks in when it senses a slip. I was very satisfied with the ride, it's much smoother than my '08 was, about like a one ton or heavy 3/4 ton truck.
in 1974 i spent some time behind a cummins ntc-335 in a kenworth w900. the interstate weight limit had just been bumped to 80000 lbs and the ntc-335 was a very common engine in those days for pulling those heavy loads. 14 liter displacement, 335 horsepower, and while i don't remember the torque rating i think it was around 850 or 950 ft/lbs.
42 years later and manufacturers are pulling 131% more power out of half the displacement and putting that into a pickup truck. progress...
/ '15 F-450 Pickup
The first diesel pickup I owned was an '82 GMC with the 6.2 diesel. About 130 hp and 250 lb/ft torque. Blew two head gaskets and cracked a head in the short time I owned it. I could barely pull an unloaded trailer at 55 mph. No problems pulling a loaded trailer at legal speeds with any of the new engines. The large displacement diesels are designed for long-term life at full load. A diesel engine designed for a pickup would not stand up to 80,000# GCWR day after day.
/ '15 F-450 Pickup #93
Funny you mention that, I just pulled a 80K semi that was broken down in the middle of the road. It was a slight incline and my rears struggled to maintain traction, but we got her out of the intersection and off to the shoulder. Driver wasn't sure it I could do it. He let me keep his chain as thanks. :laughing:
/ '15 F-450 Pickup #94
Could we get a 2.5 year update on the pickup?
/ '15 F-450 Pickup #95
It just turned 100k towing my 5th wheel. Scaled at 25K total and didn't feel the trailer at all.
So, the bad news is at 85K the High Pressure Fuel Pump (HPFP) failed. This has happened to a few people, although it seems that post 2015 the incidents have decreased markedly. Of course Ford says it is water in the fuel, but this truck never has given a water in fuel (WIF) warning and I put the DieselSite filter kit on in the first 500 miles. If the fuel pump was destroyed by bad fuel, it got there through four filters and without any warnings. Thus, most of us that have had this do not believe Ford's explanation. The repair involves replacing the entire fuel system between the tank and the injectors, approximately $10K. Now, for most people, including me, insurance covers it under comprehensive loss.
I knew when I bought the truck that there were reports of this failure, so I bought the extended warranty, which turned out to be worthless since the claim was denied.
Some will say that I did something wrong. I don't believe that based on my usage and fueling. I will say that outside of this failure, the truck has been perfect. I'm watching for any other reports on the newer trucks, but really haven't seen any, so most likely, I'll get another one when the time comes.
/ '15 F-450 Pickup
Still running great at 26,000 miles. Got a check engine light last summer and they had to replace an exhaust gas temp sensor.
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2011 HMDE GOOSENECK SPOOL TRAILER (A65643)
2011 HMDE...
Vermeer 605 Super F Round Baler (A65640)
Vermeer 605 Super...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2016 GMC Sierra...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
