Tricks for finding suction-side air leak?
/ Tricks for finding suction-side air leak? #1
lhfarm
Central Indiana
NH TC40DA
I've been looking a method to test for an suction-side air leak. This is on one of my farm jeeps. I'm "foaming" the fluid. I've read about putting oil on the fitting and listening for a change in pump sound. The pump is driven off the crankshaft, so heard to hear the sound of the pump separately from the motor. Anyone have a trick/technique to identify leakings in this situation?
Thanks,
/ Tricks for finding suction-side air leak? #2
If you can get saran wrap to suck into a joint but there has to be enough of a leak to create the vacuum to make this visible.
/ Tricks for finding suction-side air leak? #3
We used shaving cream placed around fitting, it will pull it in where the leak is.
/ Tricks for finding suction-side air leak? #4
Smoke or steam or spray with WD40 and watch the hose dry. I would expect the leak to be there under pressure, too. Can you seal the pump cap and use a spare cap with a Shraeder valve in it to precharge the reservoir ?
/ Tricks for finding suction-side air leak? #5
Just use thick grease on all suction parts.
/ Tricks for finding suction-side air leak? #6
This is a good one, BUT pressure must be limited to just a few psi in a foolproof fashion. Suction leaks can be very small - so small as to not be observed leaking outward at 0 pressure -- and slow to appear at low positive pressure.
/ Tricks for finding suction-side air leak? #7
X2.....
Don't forget to pack grease around the pump shaft seal......an exposed failed pump shaft seal can
suck in air too making foamy oil
X2.....
So is the grease a "fix" vs a means of founding the leak? That would be fine with me. I only have 3 fittings (pulse the shaft). My guess is the leak is at the manifold where I have an elbow. It has to be at the correct angle so I can attach the hose. I suspect that I don't have it screwed in tight enough. Perhaps I could find a swivel elbow?
Thanks
/ Tricks for finding suction-side air leak? #9
Thanks
Then put a drop of loctite all the way around the fitting and then start up momentarily. It will suck into the leak path. Cut off and allow about a day to harden in the confined path.
/ Tricks for finding suction-side air leak? #10
Not a fix, only a path to finding the culprit.......then a direction to the fix
I finally got around to working on the pump. I purchased some LockTite hydraulic thread lock and that seems to have solved the leak. Thanks for all the help.
John Deere 4520 (A60462)
John Deere 4520...
1063 (A64280)
1063 (A64280)
karcher pressure washer (A61567)
karcher pressure...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
