Tricks for finding suction-side air leak?
/ Tricks for finding suction-side air leak? #1
lhfarm
Central Indiana
NH TC40DA
I've been looking a method to test for an suction-side air leak. This is on one of my farm jeeps. I'm "foaming" the fluid. I've read about putting oil on the fitting and listening for a change in pump sound. The pump is driven off the crankshaft, so heard to hear the sound of the pump separately from the motor. Anyone have a trick/technique to identify leakings in this situation?
Thanks,
/ Tricks for finding suction-side air leak? #2
If you can get saran wrap to suck into a joint but there has to be enough of a leak to create the vacuum to make this visible.
/ Tricks for finding suction-side air leak? #3
We used shaving cream placed around fitting, it will pull it in where the leak is.
/ Tricks for finding suction-side air leak? #4
Smoke or steam or spray with WD40 and watch the hose dry. I would expect the leak to be there under pressure, too. Can you seal the pump cap and use a spare cap with a Shraeder valve in it to precharge the reservoir ?
/ Tricks for finding suction-side air leak? #5
Just use thick grease on all suction parts.
/ Tricks for finding suction-side air leak? #6
This is a good one, BUT pressure must be limited to just a few psi in a foolproof fashion. Suction leaks can be very small - so small as to not be observed leaking outward at 0 pressure -- and slow to appear at low positive pressure.
/ Tricks for finding suction-side air leak? #7
X2.....
Don't forget to pack grease around the pump shaft seal......an exposed failed pump shaft seal can
suck in air too making foamy oil
X2.....
So is the grease a "fix" vs a means of founding the leak? That would be fine with me. I only have 3 fittings (pulse the shaft). My guess is the leak is at the manifold where I have an elbow. It has to be at the correct angle so I can attach the hose. I suspect that I don't have it screwed in tight enough. Perhaps I could find a swivel elbow?
Thanks
/ Tricks for finding suction-side air leak? #9
Thanks
Then put a drop of loctite all the way around the fitting and then start up momentarily. It will suck into the leak path. Cut off and allow about a day to harden in the confined path.
/ Tricks for finding suction-side air leak? #10
Not a fix, only a path to finding the culprit.......then a direction to the fix
I finally got around to working on the pump. I purchased some LockTite hydraulic thread lock and that seems to have solved the leak. Thanks for all the help.
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2024 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2024 B and B...
429858 (A61165)
429858 (A61165)
