DK-40 Starting issues
/ DK-40 Starting issues #101
I find those non-contact IR thermometers (which are now quite affordable) work well except on shiny surfaces, like galvanized exhaust ducting. Otherwise a good imagination can concoct many practical uses for the things, like finding heat leaks from your house, diagnosing engine cooling system problems, and even checking glow plugs without removing them.
I'll test for current going to the relays this weekend as it will be cold enough for the glow plugs and I'll have another set of hands.
/ DK-40 Starting issues #103
I'll test for voltage going to the relays this weekend as it will be cold enough for the glow plugs and I'll have another set of hands.
Fixed if for ya. :) You can test for the voltage. with a voltmeter. You cannot really know the current the glow plugs are drawing without measuring the current with an amp meter. And that requires a big one as the glow plugs will draw between 60 to 70 amperes. It is a minor semantic point, but if you are starting down "knowledge road" you might as well start using the correct terminology.
You can measure current by measuring voltage drop across a known resistance. This is the way ammeter's are made. A voltmeter measuring voltage drop across a calibrated meter shunt.
The reason we can do this is because of a well know law that was worked out by a fellow named Ohm. Yep, Ohm's law is not just a good idea, it is the law. In DC circuits E=IR Always have and always will. E is Electromotive force measured in Volts. "I" stands for current measured in Amperes (another famous man) and R stands for resistance to the flow of current.
Once you get the locked in relationship of voltage, current, and resistance figure out in your head, everything will become clear to you.
We can go on if you want, or if you are sick of hearing me yammer on about this we can quit here.:)
Knowledge is power so by all means continue.
So I need to find out if the glow plugs are working. I have new relays now for what its worth. The preheat controller is still the original one on the tractor.
Don't be afraid to " dumb " down this procedures.
/ DK-40 Starting issues #105
As in the above example you can test for the presence of voltage on the glow plug buss with a voltmeter, buy you probably won't know with certainty that the glow plugs are drawing current or not.
Let me give you an example. If you find 12 volts on the glow plug buss during the glow plug cycle, as controlled by the glow plug control timer and as switched onto the buss by the robust glow plug relay, how will you know if the glow plugs are all "open circuit" or not?
If the glow plugs are open circuit, they will not draw any current, or if only one glow plug is still within the resistance specification of about .4 ohms and the others are open how will you be able to determine that?
What do I mean by open circuit? I mean a circuit with infinite resistance to current. A glow plug is nothing more than a very low value resistor heating element. Somewhere in the less than 1 ohm of resistance. My Kioti manual say mine are .43 ohms each. and when placed in parallel the resistance is even less. So the glow plugs are a lot closer in value to a "dead short" than an open. An example of a "dead short" would be a chunk of wire. So a wire must be "shorted" by design and manufacture to function as a conductor of electricity. A lot of folks have a lot of trouble understanding the terms "open" and "shorted" Which are very loose terms indeed and can mean different things to different people.
But do wires and relay contacts have zero ohms of resistance?.. Um. not quite, they all exhibit some resistance to current and therefore have a resistance value although a very low one.
Now lets do a "thought experiment" where we don't actually do this, we just think about the results and apply logic and reason.
Take 1000 foot of 24 gauge wire, which is pretty small wire. and we look up in a table provided by the manufacture how many ohms of resistance it will have over that 1000 foot span. The table says 25 ohms. Oh wow! that is a lot more ohms than those glow plugs.
So we apply 12 volts to the battery end, and measure the voltage on the other end with a good voltmeter. What will it be? Will it have dropped by having to go thru that 25 ohms of resistance?
Well lets see now: E=IR so the voltage should be the current times the resistance right?. so...hey we don't know the current so how can we solve the equation for voltage drop if we don't know the current?.. hmmm . I did say the voltmeter was a good one, that will draw next to nothing in the way of current by making that measurement..... so I guess the current being 0 multiplied by the 25 ohms is still about zero huh?
So the voltage drop across a 25 ohm resistor in the form of 1000 foot of small gauge copper wire is near 0 volts of drop, so we would have the same 12 volts on the far end as we stuck in on the near (battery source end).
Now OK, lets try to draw some current thru that 1000 foot of small gauge wire.. Uh. oh... this is going to get dicey real quick. Lets start by putting a small load on this wire at first. Lets just put a 100 milliamp load on it. So a milliamp is 1/000 of an amp (Ampere) so 100 of those is 1/10 of an amp (Ampere) so far so good?
So lets do some quick calculations. E=IxR so we are solving for the E or the voltage drop in this circuit. E= .1 (amps) X 25 (ohms of resistance) so then .1x25=2.5 volts of drop with a pretty small load. So we could expect about 9.5 volts to be measured at the end of the wire with a very modest load on it. If we increase the load on this system, the voltage will continue to plummet all the way to zero volts.
What if we put one of our glow plugs on the end of the 1000 foot of 24 gauge wire and ground of the battery. Would we be able to power our glow plug up? After all we just got done measuring 12 volts on the end of the wire, so lets throw this glow plug on it and see what happens.
What will happen?
What if we increase the length of the wire to 2000 feet instead of 1000?. We will just drop twice as much voltage with a given load but the open circuit voltage will still measure 12 volts at the end of that 2000 foot of wire.
So the point to all of this "stuff" is that when you measure the voltage on the glow plug buss, you know the relay contacts are contacting the source battery to the buss, but you are still not sure the glow plugs are working. And by working I mean drawing massive amounts of current because of their extremely low resistance and making lots of heat in the process.. hmmmmm. Wait a minute you say...If they are a really big load and draw lots of current, shouldn't we get some voltage drop across the wiring and the relay contacts and even the internal resistance of the battery itself?... (light bulb comes on inside his head)
Yeah you should. Well, can we maybe see that voltage drop? Yeah we can. But the rub comes in in determining how much, and how to determine if ALL the glow plugs are working or just some of them.
Say your battery resting voltage is 12.7 volts. and you fire up the glow plug cycle, and you measure 12.65 or something on the glow plug buss. Are the glow plugs working? Probably not. Because the relay and the timer may drop voltages in the system a little bit like that, but remember these dang glow plugs are like dropping a crow bar across your battery.. it should knock the heck out of it voltage wise. And the resistance's in the wiring and relay, and the internal resistance of the battery itself should result in some pretty hefty voltage drops. maybe as much a 2 volts of drop. So if you measure maybe 10.5 volts on the glow plug buss in those few seconds it is operating, then likely they are working. BUT you can never be sure with this "estimating" method.
This is why you can use the infrared thermometer I discussed earlier or take off the glow plug buss and measure each plug's resistance to determine if they are "burnt out" (open) or within the resistance spec.
Probably enough to think about for now...I am sure you are probably tired of this game by now. Ask more questions if you want to go on.
What will happen?
That is all good material and very much appreciated.
I never tire of knowledge just tire of troubleshooting these issues but hey I'm learning so not a loss.
While I have my hands in the tractor is there a way to test the preheat controller while is is disconnected? Its another part that's easy to access figured why not test it as well you know?
/ DK-40 Starting issues #107
You can save yourself the extra credit course in electrical theory, and just test the glow plugs by trying to start the tractor when cold and see what happens withOUT glowing the plugs on Saturday, and then doing the same but GLOWING them on Sunday. If they miraculously start easier on the Sunday, (test at approximately the same ambient temp), you can hypothesise that the plugs, or some of them, are functioning; if no change, then they are likely NOT working, and need further examination.
/ DK-40 Starting issues #108
Yes, but how is he going to write his thesis that way... He has to understand the material if he expects to get his degree..;)
/ DK-40 Starting issues #109
In a word no. It is a complex circuit and a special jig would have to be fabricated to substitute for the tractor and all of its connections.. No doubt there is one in Korea...
/ DK-40 Starting issues #110
How about this billy boy trial. Heat up the glow plugs for a spell and feel if the cylinder head is warm by the glow plugs?
Well got out to the tractor this weekend with nothing more than a multimeter. Battery is still reading great voltage!
I got a reading on the glow plugs of many readings ranging from 8-10 volts. Not stable to say the least. But the most common was 10.80v
At least current is getting to them and the replaced relays are functioning properly.
/ DK-40 Starting issues #114
Seen this post as I am checking out the glow plugs and preheating system on my DK45.I have a DK40 service manual,when I bought the tractor some one had wired a push button switch into the preheating circuit on the firewall.Must have had trouble getting the glow plugs to work or did not know that ignition switch needs to be held past on position for a while before starting tractor.I did a quick check on original wiring before removing add on push button wires and everything looked good,last owner did not butcher any wires or connections:)
This year when cold starting after holding ignition switch for 20-30 seconds to heat glow plugs tractor would start and kill like it ran out of fuel.After trying a few time it would start and keep running fine.I am looking into what I need to fix.
Checked voltage at glow plugs when holding ignition switch past on,and get 8volts,down from 12v while glow plugs are drawing current.Glow plugs must be working because tractor starts easily when about 20 deg outside.Found the engine killing just after starting was from wearing gloves as the ignition switch on position is touchy and barely touching key will open stop solenoid and kill tractor.
The glow plug light on dash has never worked since I bought it a couple years ago.After looking at wiring diagram for preheating system,the only way glow plug light gets power is thru preheat controller on the firewall.So when holding ignition switch past on glow plug light will not be lit even though glow plugs are heating.
So even though I can start and run tractor even when it is cold out,I should fix preheating system because it will keep glow plugs heating for a while after tractor starts,and automatically heat glow plugs when ignition switch is turned on when engine is below 60deg.
Checking wires to preheat controller black/red is coming from ignition switch when holding past on,also goes to glow plug relay on firewall,right side of tractor.This means that the ignition switch and the preheat controller power the glow plug relay,so I wont have to hold switch to heat glow plugs every time.
Powered green/yellow wire to get glow plug light on dash to light.
Checked red/white wire for 12v when ignition switch is turned on.
Checked blue/black wire for 12v when ignition switch is in start position.
Checked blue/green wire to see that it is connected to temp sensor near thermostat,seems terminal is grounded when tractor is cold.Tried unplugging terminal to get a non grounded signal for the preheat controller to get it to power light on dash with no luck.
So it is looking like preheat controller is getting everything it needs to work but is not working.
I would like to know if my coolant temp sensor is working as it is supposed to before I buy a new preheat controller,seems the whole preheating system is run from the coolant temp sensor reading below 60deg,above 60deg the controller will not power glow plug relay or dash light.
/ DK-40 Starting issues #115
I am having the same issue with my 2007 DK65sc. Glow plugs work when switch is held in manual heat position but not automatically. Also had the shut down when key is released, that I attribute to the key switch/fuel shutoff so I ordered a new key switch. I did see the the glow plug light come on once so I am going to clean all connections when the switch arrives and check the relays. Hopefully not the controller as i dot want to take apart the dash. I hadn’t thought to check the temp sensor, maybe it can be tested.
/ DK-40 Starting issues #116
for CANMAR and CASE: Kioti key switches (at least from the era of my 2006 model) are problematic. Dirt and corrosion get in the electrical part of the switch and cause unreliable connections. This is a particular problem for the later mechanically injected models where any glitch in the hold current to the stop solenoid stops the engine and it also confuses the glow cycle.
The switch is a simple device that can be disassembled and cleaned (see ignition_switch). Springs in the switch can get lost so use care if you decide to disassemble.
However, squirting WD-40 in the key hole using the "straw"(and cycling the switch several times) usually works as well as cleaning the switch. So I recommend trying a WD-40 treatment before trying anything harder or more expensive.
/ DK-40 Starting issues #117
I lubricated, then disassembled and cleaned, then lubed again and the glow plug problem persists. The engine stays running now but the lock part of the switch seems a bit rough. I will i will test the relays and controller after i install the new switch.
2019 GENIE S-60XC' TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC'...
2016 John Deere 318G Skid Steer Loader (A61166)
2016 John Deere...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2008 Wabash National Dry Van Trailer, VIN # 1JJV281W68L109579 (A61166)
2008 Wabash...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
